Question about Coffee Makers & Espresso Machines
I have a Lavazza Espresso Point, after I use the steam wand and press stop it will not stop
2 Suggested Answers
  • 10 Answers
SOURCE: Lavazza point espresso machine no steam
Sounds like a clogged steam pipe or a jammed two-way valve. First, I would try unfolding a small paper clip and then stick it up the spout of the steam pipe. if this does not free up the steaming arm then it is most likely a clogged two way valve. Should you need service you can call 781-393-2929. we are an authorized lavazza distributor and service center
Posted on Aug 25, 2009
Lavazza does not steam
put in steam nozzle something like a long needle or something similar.
Dec 07, 2013 | Lavazza Espresso Point Capsule Machine
Need a canadian supplier for lavazza espresso point capsules
Lavazza Products may be ordered online in Canada from the following site:
http://www.espressocoffeeitaliano.com/ourproducts.php
Contact Information:
Espresso Coffee Italiano of Canada Ltd.
(authorized distributor of the Lavazza Espresso Point System)
201 Drumlin Circle, Unit #3, Concord, ON
L4K 3E7, Canad
Tel: 905-907-5049
Fax: 905-760-5606
Email: info@espressocoffeeitaliano.com
Dec 13, 2011 | Lavazza Espresso Point Capsule Machine
Our machine will not make coffee or water will not come out of the hot water dispenser.
water and steam wand work
but i cannot get any response when i press the cup buttons
Feb 08, 2011 | Lavazza Espresso Point Capsule Machine
Steamer appears clogged. How do I take the steaming arm off to clean?
depends on the model try reaming out with a small thim paper clip, straighten out and slide up the little hole on the tip of the wand contact me www.lavazzarepair.com
Nov 12, 2009 | Lavazza Espresso Point Capsule Machine
Lavazza Expresso Point Machine - not able to steam the milk - that part of the machine has no steam capabilities
The wand is clogged try reaming out with a small thin paper clip straighten out and insert thru the hole in the tip of the wand contact me www.lavazzarepair.com
Oct 24, 2009 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point Matinee No steam out of spraut
Try unfolding a small paper clip until it is straight, stick it up the steam pipe and move it around, if this does not work, then it is most likely that your two-way valve is in need of cleaning. Should you need service you can contact 781-393-2929. We are an authorized Lavazza distributor and repair center.
Aug 10, 2009 | Lavazza Espresso Point Capsule Machine
Steam wand not working
BEFORE YOU DO HAVE IT REPAIRED TRY SOAKING THE WAND IN BOILING WATER THE MIKE SOMETIMES CLOGS IT UP AND THE ONLY WAY IS TO SOAK IT IN BOILING WATER I PUT A CUP UNDER IT AND JUST HOLD IT WHILE IT SOAKS THEN JUST LET THE STEAM DO THE REST
Mar 25, 2009 | Lavazza Espresso Point Capsule Machine
My Lavazza steaming wand sputters and emits less than powerful steam, certainly not enough to foam the milk. It did this before for awhile, then worked pretty well although I don't think the steam was...
Now I see how to send a reply. THANK YOU!!!! to "frainpeggie" for the solution to my problem that he or she gave to someone else. I soaked the steaming wand in boiling water as suggested and it's back to new!! I'm so excited, but I feel stupid I didn't figure it out myself - they sure don't tell you to do that in the directions for cleaning. I meticulously cleaned it every day but never considered soaking it. I actually considered shipping it out for service - would have cost a fortune! Thanks, guys!!!!!!! You're the best.
Mar 23, 2009 | Lavazza Espresso Point Capsule Machine
Jan 06, 2009 | Lavazza Espresso Point Capsule Machine
Coffee Makers & Espresso Machines Logo
47 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
