Why does the machine loose suction
Machine will be working fine then there will be a small popping noise and the machine will stop sucking up water. I can turn it off and back one and it will start working again
SOURCE: water suction
Here's what I did. On the top of the water bucket there is a red oval screen, remove and clean the screen and replace. Also, next to the screen is an oval opening which meets up with a black oval gasket on main unit. Inspect the gasket and replace if dry or cracking. Otherwise, if it looks good, reseat the gasket (it fits into some grooves). When you fill the bucket and put the the top on, put it in the machine and make sure it is making good contact against the gasket. This worked for me. I also found a repair manual for these units that could be helpful located at: http://www.bissell.com.au/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Posted on May 24, 2007
SOURCE: shop vac sucks water for a few seconds then it spits it back out
Don't use the paper filter for sucking water. It can ruin it. It will still be usable if you just set it out to dry but there is no reason to use it for water in my experience. I have a sears shop vac and it will fill up more than half full without ejecting the water.
Posted on Mar 15, 2009
  • 20 Answers
SOURCE: odometer stopped working. speedometer works fine.
Possibly a little gear inside the odometer has broken down. You find theese gears easily on E-Bay. http://shop.ebay.com/?_from=R40&_trksid=m38.l1313&_nkw=volvo+850+odometer&_sacat=See-All-Categories
Posted on Jul 20, 2009
heatman101
  • 43501 Answers
SOURCE: not sucking up water off carpet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fgqwe
Posted on Sep 30, 2010
  • 436 Answers
SOURCE: The rotatory brush stopped turning
Found on website "dysoninfo.com"
A problem I have run into a couple of times at home, generally when I am cleaning the bathroom, is that my Dyson brush won't turn. First off I would say be sure to check that you haven't pressed the button that turns the brush on and off, as silly as it may seem it may actually be the case. But if it isn't follow the steps below to clean your brush and get it working right again.
First and foremost always unplug your Dyson before you start any sort of work on it. Next grab a seat on the floor, yeah park your butr on the floor it will be easier because you won't be trying to lift your vacuum up to you. Now take a look at the brush bar to see how much hair and debris is caught in there. If there is very little then you probably don't have much to worry about and you can press the brush reset bar on the side of the vacuums head and your problem with they Dyson brush not turning in fixed. However if you are like me and you find that your cat, dog, and wife's hair are wound pretty tightly around the brush head you will need to take some time to pull in out of there as it is probably what is restricting the motorized brushes movements. Once you are finish you can also press the button on the side of the vacuums head. Now stand the vacuum and yourself back up and go plug it in. I bet that if you cleaned it out your Dyson brush will turn as normal.
Posted on Mar 20, 2011
My QL60 just stopped sucking. The motor and fan run fine.
If the fan is running there has to be suction. If there is none it is because the air in entering via some other port and bypassing the normal intake. Check it out. Check hoses and fittings.
Mar 05, 2016 | Vacuums
My hoover max extract dual v stopped sucking up the water on just its second use. Any ideas on how to fix this problem?
The most likely problem is there is a restriction somewhere or a suction leak. Check to make sure you have good suction where the waste water tank fits down onto the machine. Make sure the lid is on the waste water tank and follow the flow of suction from the machine through the waste tank down to the floor and look for debris clogs or any area where there may be a suction leak. If you have good suction coming from the machine the problem has to be somewhere between there and where the water is being sucked off of the floor.
Oct 24, 2013 | Hoover MaxExtract Dual V Carpet Cleaner...
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
Suction problem
Possible Problem #1: The dirt water tank lid may be the reason the machine is not sucking up the water. There is actually a gasket on the bottom of the lid where it connects to the actual tank itself. If the lid is not put back on properly (this is really easy to do, I've done this myself many times on my Hoover SteamVac), and the gasket is not sealing the lid to the tank, this will allow the suction to leak, greatly diminishing the suction power to **** the water back up. Try removing the lid and reinstalling it, making sure that it's put back on the correct way, and try to see if this fixed your problem.
Possible Problem #2: The Hoover SteamVac's like yours have a very poorly thought out design flaw to them on the attachment hose. Where the attachment hose connects into the SteamVac when the machine's handle is lowered to get underneath furniture, and is close to the ground it puts a lot of stress on the hose where it connects into the machine (not the end the attachments go on, but the other end). This will cause the hose to tear at the stress point. This is a very common problem unfortunately, and I suspect might be the cause of your suction loss. To check this, remove the dirty water solution tank from the machine completely. Step on the handle release pedal to lower the handle part to the ground. Look at the lower part of the handle portion of the machine for where the hose enters into the handle section, then follow the hose to where it connects into the machine. Right at the end of the hose, before the hose cuff that's connected to the motor, inspect this part on all sides to see if you have a tear here. If you do, this is the reason the machine is not sucking water up off of the carpeting.
Possible Problem # 3. If neither of the first two possible problems were the source of your suction loss, try this one. Turn the machine upside down (you should probably remove both the clean water tank and dirty water tank before doing this, just to ensure that no water spills when you turn the machine over) so that the brushes are facing upwards. Look right behind the brushes for two red plastic tabs that are slightly sunken into the bottom housing of the machine. Pull these two tabs upward as far as they will go. There is a metal filter screen that will be exposed when you pull the tabs. Make sure that this screen is clear of debris. This screen protects anything from going into the motor, and if it has debris blocking it, this can cause the machine to loose suction.
Also make sure that there is nothing in the clear plastic suction channel on the top of the machine where you can see the water being sucked up. Sometimes if something gets stuck in this suction chamber, this can also cause the machine to loose suction.
Also it may be that your motor is dying, and loosing suction power. Usually if this were the case the motor would continually get louder and louder, until it just stopped working. To test this, put the machine in the upright position, and remove the dirty water solution tank. If you look at where the dirty water tank rests, you should see a circular tube underneath of where the dirty water tank sits. Here's a picture that I took, that has this part circled: Put your finger down into this suction port and see if you can feel any suction coming through when the machine is running. If there is suction, then your problem is definitely going to be one of the above problems, and if there is no suction, this indicates a more serious problem with your motor. If you don't feel suction here, you may want to consider taking the machine into a repair place, or even consider to possibly getting a new machine at this point.
I really hope that this helped you find the cause of your suction loss. If you were able to diagnosis this problem, and would like me to help you fix the cause of the suction loss, I'd be more then happy to now walk you through the repair as well. Please just use the Clarification Request form here on the same page, and I will then help you out with your repair. I just ask that if this repair was helpful to you, please help other Fixya members to find it, and rate the repair helpful by clicking the 4 Thumbs Up icons in the top corner of the repair.
Thanks,
Chris Jones
GoVacuum.com
May 11, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My steam vac stopped sucking up the water. How do
Hi There,
Here's a link to the instruction manual for your Hoover SteamVac. There is a trouble shooting guide in the back of the book that will explain how to check no suction problem.
If none of these suggestions fixes your machine, please just refer to my answer below the link, these are the problems you may have.
Here's the link:
http://www.hoover.com/pdfs/manuals/F5914900.pdf
There could be several problems that would cause the dirty water tank to be empty after you've cleaned the carpets. I'll try and walk you through each to help you diagnosis the problem.
Possible Problem #2: The Hoover SteamVac's like yours have a very poorly thought out design flaw to them on the attachment hose. Where the attachment hose connects into the SteamVac when the machine's handle is lowered to get underneath furniture2_bing.gif and is close to the ground it puts a lot of stress on the hose where it connects into the machine (not the end the attachments go on, but the other end). This will cause the hose to tear at the stress point. This is a very common problem unfortunately, and I suspect might be the cause of your suction loss. To check this, remove the dirty water solution tank from the machine completely. Step on the handle release pedal to lower the handle part to the ground. Look at the lower part of the handle portion of the machine for where the hose enters into the handle section, then follow the hose to where it connects into the machine. Right at the end of the hose, before the hose cuff that's connected to the motor, inspect this part on all sides to see if you have a tear here. If you do, this is the reason the machine is not sucking water up off of the carpeting.
Thanks,
Chris Jones
GoVacuum.com
Apr 23, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Frigidaire FWX233RES4 washing machine won't work
Sounds like there's something such as a small sock that has gotten sucked into the pump. This will keep the pump from spinning, cause extra noise, and the belts may appear fine but it may be stretched... if you're willing to deal with a little disassembly, unhooking hoses, spilling some water, you can probably handle this.... Good luck and let me know if you need any more assistance..
K
May 10, 2009 | Washing Machines
My Bissell Dirtlifter Powerbrush carpet cleaner will not roll. The back wheels roll fine, but when you put the machine down flat, the front part (where the roller is) sticks and will not roll.
I had the same problem. It would pull backwards but not go forward. A closer examination revealed the clear plastic part on the bottom in the very front of the machine had popped loose on one side.
If you look at the front of the machine, there is the clear plastic part on top where you see the dirty water being sucked up. The bottom half that creates the channel for the vacuum is where it came loose. It wouldn't create enough suction to draw the water up either. By taking out the two screws that hold the top part in place and removing it, I was able to snap the bottom back in. Works fine now. Hope this helps.
Apr 14, 2009 | Vacuums
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
