Question about Motorola Mobility RAZR2 v9 Cell Phone
I put the battery on the motorola razr upside down and now it won't come out through pushing down and sliding it. Safe way to remove it?
  • 31 Answers
Ok get a pencil
Posted on Jul 25, 2009
How to remove a battery from Droid Razr
Ignore some of these my gently pop the back. Off thru the seam. U can do it with your nails. It's glued to the batter so. Use something like a. Butter knife and work it down thru but pushing up not. Down. You don't wanna puncture battery. Separate it from the battery. Then remove. The red. Rubber protector. Over the two. Screws St the. Bottom. Left I. Think. It is. Remove screws then use the tab that says pull to remove or whatever be careful. Not to tear the flex cable.... Those batteries aren't cheap
Aug 20, 2012 | Motorola Mobility Droid Razr
How can i make a motorola razr v3i accepts sd memory card 4gb
    • 1 Hold down the "End Call" button for several seconds to turn the phone off.
    • 2 Remove the battery cover. Turn the phone over and push the clamp on the backside of the unit. The cover should slide up easily; remove it and set it aside.
    • 3 Locate the memory card slot. It is located directly under the battery under a black cover.
    • 4 Pull out the black cover gently to reveal the memory card holder.
    • 5 Slide and press the memory card into place.
    • 6 Replace the black cover on top of the memory card by sliding it back over the card and pressing firmly in place.
    • 7 Close the battery cover; place the cover on its grooves and push gently until you hear a click.
    • 8 Turn on the Motorola phone. If the memory card was installed correctly, you can save contacts and other data immediately.
Apr 11, 2012 | Motorola Mobility RAZR V3i Cellular Phone
Looking to replace speakers and don't know how to take apart
browse to the internet for motorola razor v3 dismantling
Oct 11, 2010 | Motorola Mobility RAZR V3
I can't work out how to get an old sim card out of my motorola razr and replace with new one - do I need to remove the battery as it is in the way? and how do I do that?
To release the battery - push down on the battery from the top of the phone and lift it out using the same motion as you used to lift the cover. The SIM will then slide out. Don't try lifting the metal strip covering the SIM, it is part of the locking mechanism and the SIM will not contact properly if this is broken.
Oct 20, 2009 | Motorola Mobility RAZR V3
I have a motorola razr v3x phone, problem with water damage
I dropped my in the bath tub giving my little girl a bath. I pulled the back cover and battery out and sat it upside down, back faceing up, under a lap and turned it over every hour. The next morning put the battery in and closed it up, no problems - till the next time it went swimming and had to repete the process.
Sep 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
How do i remove my motorola razr v3 br50 battery
take off the back plate, push down on the battery, you should feel it give a little. While pushing down, tilt it back. It should come right out.
Jun 24, 2009 | Motorola Mobility RAZR V3
How do i get out the sim card
remove the back from your phone. hold the phone upright, push down on the top of the battery and pull it away from the phone. If the sim card does not want to slide out easily use a pensil eraser to slide it out.
Nov 17, 2008 | Motorola Mobility RAZR V3
How to remove battery on Razr2 V9?
I have a RAZR V3C and the rear battery panel has to be removed first to gain access to the battery.
Looking at the rear of the RAZR and at the top, there should be a chrome spring-loaded panel that you can push in with your finger nail. That will unlock the rear panel.
Once the battery cover is removed, the battery will pop out by grabbing ahold of it at one end and lifting the end up and out.
Let me know if I can be of further assistance to you.
- Jim
Feb 07, 2008 | Motorola Mobility RAZR V3
Charging problems
I had the same problem. Take the back off your phone and push down on the battery (the same way you would to install the sim card) so it slides down to make better contact with the battery contacts. I had the same problem and ended up taking a thin piece of paper and sliding it between the battery and the tab at the top of the phone that holds the battery in tight to the contacts.
Aug 03, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR2 v9 Cell Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
