SOURCE: Won't stay running...
I had the same problem with my mantis. It would start fine after a few pulls, but had no power. I changed the plug, replaced the carb completely...nothing helped. Took it to a shop and paid $70 for a tune up that didn't help at all, and the shop owner just said "sorry".
After everything else was done, I pulled the cover off the muffler, (3 screws) then removed 3 screws over a small spark arrestor screen and found it was clogged...cleaned it and guess what...IT WORKS FINE NOW!
The best and easiest fix I have ever done to a small engine. I felt like an idiot, because the exhaust side of the motor MUST be clear to work properly on small engines. The only reason I was removing the muffler in the first place was to check the compression and VOILA!!!
An easy and quick fix I recommend for all Mantis tillers before you waste money on carb issues (which is what the company will tell you to fix to solve this problem).
SOURCE: No Spark from coil
I have problem with coil not working. In the morning,car with not start, but if I run a wire from battery to (+) to coil (+) will start. the rest of day no problem,car will start. but next morning same problem no spark from coil. c
SOURCE: Unable to pull starter cord at all
pour some gas/oil mixture down sparkplug hole and let it soak and see if the rings are carbon blocked
SOURCE: 2000 honda 1100 shadow spirit. Rough idle, little power.
Replace the spark plug caps and try again. On Honda's the cap is often part of the wire (a dealer part) NGK makes some inexpensive plug caps about $5 each. They should OHM out to 5000 anything above or below and you need to replace them. This should fix the problem.
SOURCE: i have no fuel at
Make sure you have flow from the tank to the carburetor. Also, when you cleaned the carburetor, there are several jets that have to be open in order for the fuel to "flow" through the carburetor. The carburetor on this generator has a pilot jet located on the top side of the carburetor and a main metering jet that screws into the very bottom of the carburetor and will be visible when the bowl is removed. After the main jet is removed there is a main nozzle that also has holes in it that have to be open also.
Another problem that is possible is compression. If the engine does not have sufficient compression it will not "pull" the fuel into the combustion chamber on the intake stroke. Hope this helps to get you in the right direction.
