Question about In Office Equipment & Supplies
I have an empty 22 cartridge stuck in my 479 power trigger and can not figure how to remove it.
    Top Expert:
  • In Master
  • 44,260 Answers
Perhaps with a cleaning rod from the open end
Posted on May 29, 2017
How do I empty the hvc-22
If you are meaning the DC24, like your post seems to be tied to, the manual can be found here:
https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/DC24_Manual.pdf and the pictures for removing the canister and triggering the lower empty-hatch are on page 3 under 'Clear Bin Emptying'.
Good Luck!
Jul 13, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Printer cartridge allignment fails repeatedly
'Printer alignment failed' Error Message Displays on the Product
Try aligning the printer again and put the alignment page on the top of the scanner bed printer will align itself make sure the printouts are facing down
A "Printer alignment failed " error message displays on the product
Follow these steps in the order presented until you resolve the issue. When one of the steps resolves the issue, there is no need to continue troubleshooting.
Step one: Load the correct type of paper
Colored, photo, or used paper can cause the alignment to fail.
1.
Remove all the paper from the tray.
2.
Load unused, plain white, letter, or A4-sized paper with a brightness level of at least 85 into the tray.
NOTE: Look for the brightness level on the paper packaging.
Step two: Align the All-in-One
1.
Press the Setup button ( ).
2.
Press the Down Arrow ( ) to select Tools , and then press OK .
3.
Press the Down Arrow to select Align Print Cartridges and then press OK . The product calibrates, aligns the printhead, and then prints an alignment page.
4.
Click OK to continue.
5.
Recycle or discard the alignment page.
If these steps resolved the issue , there is no need to continue troubleshooting.
If the issue persists , see the next step.
Step three: Check the ink levels
Empty or nearly empty cartridges might cause alignment failures. Follow these steps in the order presented to check the ink levels in the cartridges.
1.
Open HP Solution Center.
Windows XP: Click Start , click All Programs , click HP , and then click HP Solution Center .
Windows Vista: Click the Windows icon ( ), click All Programs , click HP , and then click HP Solution Center .
HP Solution Center opens in a new window.
2.
Click Settings ( ).
3.
In the Print Settings area, click Printer Toolbox . The printer Toolbox opens.
4.
Click the Estimated Ink Level tab. The estimated ink levels display in a new window.
Figure 1: Estimated Ink Level window
Illustration of Estimated Ink Level graphic
If either of the cartridges is empty or low on ink, continue to the next step.
If the ink levels in the cartridges are sufficient, skip to Step five: Clean the cartridges .
Step four: Replace the cartridges
Follow these steps to replace any cartridges that are empty or low on ink.
1.
Press the Power button ( ) to turn on the product.
CAUTION: If the product is off when you open the cartridge door to access the cartridges, the product does not release the cartridges for changing. You might damage the product if the cartridges are not in the dock when you try to remove them.
2.
Open the cartridge door.
Figure 2: Open the cartridge door
Illustration of opening the cartridge door
3.
Wait until the print carriage is idle and silent, and then lightly press down on a cartridge to release it.
NOTE: To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
Figure 3: Press down on the cartridge to release it
Illustration of pressing down on cartridge to release it.
4.
Pull the print cartridge toward you out of its slot.
NOTE: The HP Inkjet Supplies Recycling Program is available in many countries/regions, and lets you recycle used cartridges free of charge. For more information, go to the HP Eco Solutions Web page .
5.
Remove the new cartridge from its packaging.
Figure 4: Remove the cartridge from packaging
Illustration of removing new cartridge from
6.
Use the pull tab to gently remove the protective plastic tape from the cartridge.
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
Figure 5: Remove the protective tape
Illustration of removing the protective plastic tape from the cartridge
7.
Slide the new cartridge forward into the empty slot, and then gently push on the upper part of the print cartridge forward until it clicks into the socket.
Figure 6: Install the new cartridge
Illustration of sliding new cartridge into the slot
8.
Close the cartridge door.
Figure 7: Close the cartridge door
Illustration of closing the cartridge door
9.
Try the alignment again.
Method one: Clean the cartridges from HP Solution Center
1.
2.
Click Settings ( ).
3.
Click Print Settings , and then click Printer Toolbox . The printer Toolbox opens.
4.
Click the Devices Services tab, and then click Clean the Print Cartridges .
5.
Follow the on-screen instructions to choose the appropriate cleaning level.
6.
Recycle or discard the page that prints.
Method two: Clean the cartridges from the Start menu
1.
Click Start , and then click Printers and Faxes .
2.
Right-click your printer icon, and then choose Properties .
3.
Click Printing Preferences , and then click the Services tab.
4.
Click Service This Device . The Printer Toolbox opens.
5.
Click the Device Services tab, and then click the Clean the Print Cartridges tab.
6.
7.
Replace empty or almost empty cartridges.
Step six: Reset and relocate the product
A power reset drains power from the product and returns the product to the same settings after restarting. Plugging the product directly into a wall outlet can eliminate any potential power deficiencies that could cause an alignment failure.
1.
Make sure that you have the product turned on. If necessary, press the Power button ( ) to turn on the product.
2.
With the product turned on, disconnect the power cord from the back of the product.
3.
Unplug the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet, preferably in another room.
4.
Reconnect the power cord to the back of the product.
5.
6.
Load plain white paper into the tray.
7.
call hp to take advantage of your printers warranty or they can provide you alternative options specially their loyalty program for Out of Warranty printers
hope i help you a bit
Mar 27, 2011 | HP PhotoSmart C4180 All-in-One Color...
HP PRINTER C6280 problem says ink system failure error 0xc18a0001
Reset the printer:
With the product turned on , disconnect the power cord from the rear of the product.
Wait at least 15 seconds.
Reconnect the power cord to the rear of the product
Remove, clean, and reinstall the printhead
remove ink cartridges
Figure 22: Lift the latch handlec01481823.jpg
Lift the printhead straight up to remove it.
Figure 24: Three areas to cleanc01481825.gif 1 - Plastic ramp on the side of the ink nozzles
  1. Figure 29: Clean the electrical contacts inside the productc01676244.gif
  2. Dry the area with a clean, dry, lint-free cloth.
Reinstall the Printheads and the cartridges
Reset the product
It should work otherwise try to replace the Printhead and instead change the entire printer its time to change it
Feb 26, 2011 | HP C6280 All-in-One Printer
The ink cartridges keep expiring and they are nearly all full .my machine is a hp photo smart 3310 all in one.How do i by pass the expiry dates on cartridges
Each ink cartridge has an expiration date to protect the printing system and ensure good ink quality. The cartridge expire date appears on line 53 of the self test report.Printing can continue without replacing the ink cartridge. Follow the instructions that appear on the HP product or on the computer. However, HP recommends replacing the expired ink cartridges. HP cannot guarantee the quality or reliability of expired ink cartridges. Service or repairs required as a result of using expired ink are not covered under warranty
As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button .
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 16, 2010 | Office Equipment & Supplies
How do i remove the bolt in a marlin 783 .22 magnum?
Remove the magazine tube and make sure the gun is empty. Open the bolt,take the safety off and squeese the trigger. Continue to hold the trigger back and gently pull the bolt back out of the breech. I beleive that is all there is to it. Good luck with your Marlin.
Nov 25, 2010 | Crossfire Rock & Ice Climbing
How do you place cartrige in printer
Step eight: Install the cartridges
  1. Raise the top cover of the product. Figure 5: Raise the cover c00830210.jpg
  2. Remove the new cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 6: Remove the tapec00442146.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  3. Slide the new cartridge forward into the empty slot. Then gently push the upper part of the cartridge forward until it clicks into place.
    • Slide the tri-color cartridge into the left slot.
    • Slide the black or photo cartridge into the right slot.
    Figure 7: Insert the cartridgec00830211.jpg
  4. Close the cartridge door. Figure 8: Close the cartridge doorc00830212.jpg
Aug 08, 2010 | HP Officejet 5780 Printer
How do you open for ink replacement?
Removing an empty print cartridges Follow the steps below to remove an empty print cartridge:
  1. Press the Access Cartridge button on the control panel. The cartridge carrier moves to the remove/install position. Figure 1: HP Fax 1040/1050 control panelc00253378.gif 1 - Access Cartridge button
  2. Open the control panel and cartridge compartment cover (it will click and remain open). Figure 2: Opening the control panel and the compartment coverc00253379.gif 1 - Control panel 2 - Cartridge compartment cover
  3. Pull the cartridge toward you until it releases from the print cartridge cradle and then remove it. Figure 3: Removing an empty print cartridgec00253380.gif 1 - Pull cartridge towards you 2 - Remove cartridge from print cartridge cradle
Installing a new print cartridge Follow the steps below to install a print cartridge.
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape using the pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. Figure 4: HP 20 print cartridgec00259017.gif
  2. With the cartridge compartment cover open, insert the print cartridge into the print cartridge cradle with the contacts facing into the unit. When the cartridge is seated in the print cartridge cradle, push the top of the cartridge towards the back of the unit until the print cartridge clicks into place. Figure 5: Inserting a new print cartridgec00253382.gif 1 - Insert the print cartridge into the print cartridge cradle 2 - Push the top of the cartridge until it clicks into place NOTE: If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
  3. Close the cartridge compartment cover and control panel.
  4. Press the Start/Enter button.
  5. On the keypad, press 1 if the replacement print cartridge is new or 2 if the replacement print cartridge is old. NOTE: When you put in a new cartridge, you must choose 1: New .When you put in a used cartridge, choose 2: Used . This helps you to check the correct amount of ink you have left.
for more information follow the link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00253364&tmp_task=useCategory&lc=en&dlc=en&cc=ca&lang=en&product=425911
Jun 18, 2010 | HP 1040 Plain Paper Inkjet Fax
Installed new cartridge, still displays empty
Hp Cartridge issue
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.
Step one: Reset the printer
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
Step two: Clean the cartridge contacts
Figure 1: Lifting the top cover
  1. Lift the top cover.
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch, then lift the latch.
Figure 2: Unlatching cartridge
1 - Black cartridge
2 - Color cartridges
  1. Remove the cartridge indicated in the error message.
Figure 3: Removing cartridge
  1. Gather cleaning materials:
    • Distilled, filtered, or bottled water (do not use tap water or alcohol or platen cleaners)
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  2. Lightly moisten the swab and squeeze out excess moisture.
  3. Holding the cartridge by its handle, wipe the copper contacts.
Figure 4: Wiping the contacts
1 - Copper contacts
  1. Replace the cartridge, then close the latch and the printer top cover.
Step three: Replace the cartridge
Apr 22, 2010 | HP Photosmart 3210 All-In-One InkJet...
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  1. Turn the printer on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Top In Office Equipment & Supplies Experts
Mohul
Mohul
Level 1 Expert
Tygh Duval
Tygh Duval
Jason
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
