Why doe my HE2 washer growl? It almost sounds like a belt is rubbing or worn out.
4 Suggested Answers
  • 141 Answers
SOURCE: growling sound when water is being added at start
Hi
The dust will be deposited at the bottom of the inner tub in huge amount it can be eliminated by putting the viniger 100ml along with 20 liters of hot water and start the normal program
if problem exists the problem will in the 2inner bearing and inner washer which connects the motor and innertub it has to be replaced
Posted on Dec 23, 2009
dcramer531
  • 1654 Answers
SOURCE: Washer is making a terrible sound, I think it is a
is the nois a grinding, whirring noise? I think the motor coupling has gone bad. Not an extremely hard repair and a repair man should only charge around $25.00 for the part and his service call. You can do this yourself if your mechanically inclined. the coupling is under the drum and you have to take the front cover off to get to it.
Posted on Nov 28, 2010
whtbuick
  • 372 Answers
SOURCE: what is the growling noise coming from my 94 civic motor
Water pump or pulley most likely.
Always replace water pump and pulleys when you do the timing belt.
Also you may have overtightened the belt.
NOTE, Kevlar belts will make a "whirring" noise for a few thousand miles after replacement, but not a growling.
Posted on Dec 29, 2014
Testimonial: "thanks"
I hear a sound like something rubbing in the motor, does having low transmission fluid the result?
Power steering pumps that are low on fluid more often make: Squealing, or growling, or humming, or chattering noises.If is a rubbing sound, take a good flashlight and see what else might be the problem.
God bless your efforts.
Jun 30, 2017 | Cars & Trucks
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
What is the growling noise coming from my 94 civic motor
Dec 29, 2014 | Cars & Trucks
Spin cycle not removing all water - seems like it used to do a much better job. Used to achieve maximum spin speed faster than it does now and there is also a low growling noise at the beginning of the...
This is a belt drive machine, it takes more power to spin than to wash if the belt is worn it could spin slower, do you smell any belt russery burnt smell?
Sep 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
My steering wheel is screeching whenever I turn it hard on my 97 Camry. The steering fluid is full. Your thoughts?
that wold be a loos belt. you mit wont to check for cracks if the belt is old or worn you mite wont to replace it.
Dec 17, 2010 | 1997 Toyota Camry
My washer will start but it will just make a winding sound
Sounds like the motor to drum belt or gear is broken. The motion generated by the motor is not getting to the drum because the belt is slipping or broken, or the gears are stripped causing the winding sound.
Sep 26, 2010 | Kenmore HE2 Plus Front Load Washer
Growling sound when water is being added at start
Hi
Dec 23, 2009 | Fisher Paykel EcoSmart GWL15
Weird rubbing or mild grinding noise when in spin cycle.
It sounds like the bearings on your tub are going. This is an expensive and difficult job to do. (approx $450 parts and labour and you may do more damage trying to take it apart)
Feb 07, 2009 | Kenmore HE2 Plus Front Load Washer
Spinning
you may have some clothing or such under the drum ,
pull back the rubber lip and look under tub.
or the drum bearing is going bad.
does it turn easily .
Dec 02, 2007 | Whirlpool LHW0050PQ Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
