Question about Sony Cyber-shot DSC-W170 Digital Camera
Opens and closes always the contact so i cant take a photo
  • 460 Answers
Remove the batteries by doing so many problems can be solve'
I own a Kodak and that works veru good for me try it and let me know if this works 4u.
Your rating and VOTE is very important to me....
I hope this information was helpful?
I like to tank you for the oportunity you give me to serve you please if you have any question or concer please e-mail me, I will be more then happy to assist you.
Sincerely
vickygomar
Posted on Jul 25, 2009
Can you open my phone for me?I forgot the password because I always use finger print access.
What phone is it ?
IOS ? Android ? Windows ? Palm ? Symbian ?
make and model would help as well
Are you ready to have a hard reset to factory done ?
which means you will loose some data including photos and contacts if not stored on external SD Card
Sep 16, 2016 | Cell Phones
Electric garage door does not always close
Check the alignment of the photo cells. If they are out of alignment, even a little bit it will behave like you describe.
Mar 31, 2014 | liftmaster Chamberlain Garage Door Opener...
Canon pixma ip6600d paper output tray closed
I know this is an old string but we had the same issue, but we caused it. After replacing the Ink Collector pads we started getting the error that the front door was close please open. What we found was when the tech put the printer back together he broke the front door switch. It is located on the bottom left of the media "block" (where you put the smart card in).
To get to it you have to remove the silver outer casing and also remove the top black shell. There is a video on youtube on how to open the black shell. Pretty much four pressure points that have to be removed, too much to post here so watch the video. Once the whole shell was open I was able to get to the switch.
Since the switch was broken and I did not have a replacement I ended up soldering the contacts together so that the switch is always open (door is always open).
Jan 12, 2013 | Canon Pixma iP6600D InkJet Photo Printer
When photcell turns off contactor vibrates and chatters. Everything rated and sized correctly
If the chattering goes on continuously until you remove power or cover the photo-cell, then your contactor (relay) is wired wrong. If that is the case, read on.... The relay is probably a double-throw relay, and it is wired in such a way that turning off the photo cell allows the relay to open, but when it opens, it closes on the other contacts, which are wired to re-energize the coil, causing it to close again. It is, in effect, bouncing off of the secondary contacts. This is exactly how buzzers and old phone ringers operate.
Good luck.
Nov 29, 2010 | Intermatic K1121 Photo Cell Control...
When it prints black cant hardly see,if i print a color and black and white you cant see black print
Common error for Printhead that some colors on your printout are missing.
1. Clean printhead twice press menu button> select clean printhead> select basic/deep clean
2. Test Print Press photo and copy button at the same time for atleast 10 sec. or until it prints
3. Reseat the printhead Simple remove the inkcartridges and the printhead close the printer access door without the printhead. Open the printer access door put the printhead and the inkcartridges back. Then close the printer access door. DO TEST PRINT if still missing colors
4. Replace printhead Contact Kodak AiO support line at 1 800 421 6699
Nov 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Ink absorber full
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge
Aug 19, 2009 | Canon PIXMA iP6310D InkJet Photo Printer
Too much green
Print cartridge
If you still cant communicate try with new cartridge .
Thanks
Thiru
Jun 15, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Close up pics W/clarity
Set the camera for the "macro" setting. This is a close focus setting. Turn the camera power on. Press the "flower/mountain" side of the command dial on the back of the camera. You should get two icons on the display...one is a mountain, the other is a flower (macro setting). Use the command dial to jump to the macro setting. You should get a large confirmation icon to tell you that the macro setting is activated. Now you will be able to get close, real close. Like 2 inches close! Good luck.
Mar 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Tmobile dash
Utilize your task manager, your phone is a mini PC the more programs you have running in the background the more your battery will drain. Every time you open your text messages or surf the net or use a program like photo contacts it runs until you close it. Going back to your home screen does not close applications you have to use your task manager.
Jan 23, 2008 | T-Mobile Dash Smartphone
Lens Error
Firmware doesn't solve lens errors. that can only be solved by sending into repairs. Give them a call at 800-706-2534 and then keep choosing option 1.
Jan 02, 2007 | Casio QV-R3 Digital Camera
Sony Cyber-shot DSC-W170 Digital Camera Logo
365 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
