My J1Ace VE SM-J111stollen how do i trace it
I forgot my samsung galaxy j1ace password. How can I unlock it?
In order to bypass a lost password you must do a factory reset.
Nov 18, 2016 | Samsung Cell Phones
I have a question if I have a to go pre paid phone but I put that sm card in an I phone and I'm on a friends wifi and I post something dumb talking about someone. If someone like the law were to trace...
all your what ifs would be started at the friends wifi then everything else would be up to an investigator and your friends information but pretty much every thing including humans [social security number ] are traced by a bunch of numbers
Jul 21, 2017 | Computers & Internet
I have a 2003 Ford Focus and I was told by a mechanic that I have a leak...Is there anyway I could find this leak myself? I'm a single parent and don't really have the money to keep paying this...
You can find any leak yourself if you want to. Get under the car and find where it is dripping below your car. Once you've found the spot on the bottom, start tracing it up as high as it goes. Once you've traced it to the source, then it's just a matter of determining why it's leaking there. Is it a broken or loose hose, is it an old gasket? If there's a lot of fluid and you just can't trace it anywhere, pressure wash the engine top and bottom real good to clean it all off and then monitor it for a couple of days to see where it originates.
Good Luck!
~Brandon
Jun 02, 2011 | 2003 Ford Focus
No power for printer. Power and printer cables firmly in place, but no power light.
The printer has an SMPS unit and can be faulty. You will need to open the printer and the power supply unit is housed at the point of the plug in of the power plug. Take the unit out, if the fuse is blown , check for short in the suge protector, the rectifiers, the filter capacitors or the SM driver,/ IC. replace the shorted component and the fuse .
The Sm transformer is a rare case too.but if there is short at the secondary section , the same issues of the power cut off can happen. So if primary side is Ok check on the sec. side disconnect to bring power back and trace.
Sep 01, 2010 | HP Deskjet 2360 InkJet Printer
My monitor power button is not working
It is possible that the main power has failed, it can be from the fuse to the Switch mode supply driver.
Check on rectifier, capacitor, Sm driver transistor,Sm transformer, the feq.oscillators for Sm,output sections.
Trace with a voltage check to identify and confirrm..
Aug 24, 2010 | Proview Computers & Internet
I ve replace vista with xp professional on acer 5315 aspire ICL50
You can download all of them they will not install if the driver is not the right one. After download run it, the software will look for the device if it can not find it it will notify you stating "The device can not be found" if it is the correct one it will complete the installation.
Jan 12, 2010 | Acer Aspire 5315 Notebook
Hyper Module repair on 50H13
you need 2 check all the caps on hyper bwd.last one i did had 31 or 32 bad SM caps
change all----22mf---2.2mf---1mf---10mf
carefull not to lift traces
Sep 16, 2009 | Toshiba 50H13 50" Rear Projection...
NOKIA 6681 SR. NO. 355660001815275 HAS BEEN MISSING DDR NO. 20 DT 27/10/2007 NOT TRACED TILL TO DATE. PLEASE DO THE NEED FULL contect no. 09915107580
it can ve traced by giving a coplaint to ur network opertor . they can tace phones with imei . contact ur customer support of opertor
Dec 21, 2007 | Nokia 6681 Cellular Phone
DELL LAPTOP PP19L - INPUT POWER FROM ADOPTER SHORT CIRCUITED - TO BE FOUND OUT
sounds like the charging circuitry is faulty. I was looking at the service manual and it looks like it is on the motherboard.
Here is the online manual, see what you think.
http://support.dell.com/support/edocs/systems/ins630/en/sm/index.htm
Dec 02, 2007 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
