Question about Pool & Spa
My lay z spa all the lights at flashing on the controls and beeping have switch it of and back on again but still doing the same thing can you help please
huuum
  • 750 Answers
SOURCE: drying light keeps flashing
You said,
Drying light keeps flashing and beeping. dishwasher will not start. turned off circuit breaker and turned back on same thing happened again.
It seems you have an electrical fault in the dishwasher and it will not permit the start of the motor,
as a safety guard.
You must have the electrical system checked for shorts .
Otherwise the motor is dead!
huuum,happy to assist you!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy.
Therefore they pay for them selves in only a few years.
You can buy New and save today.
Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
Bless You, let me know how it goes.
huuum
Please give me a good rating for my fine advice before you sign off.
Thank You
Posted on Sep 18, 2008
  • 104 Answers
SOURCE: reversed polarity while jumping lexus sc430..HELP!
its very possable the ecu is damaged, but you will need to check all the fuses and or fuseable links
Posted on Apr 17, 2009
SOURCE: westinghouse mastermind 700 flashing HE
I just had to lighten the load. I think that HE means heavy. It works fine now.
Posted on Aug 24, 2009
  • 990 Answers
SOURCE: We have refiled our lay z sap, after it dispaly shows 3 dashes
You probally just need to break an air lock in the pipes. You can ether force water down the skimmer pipe or find your drain valve and open it for a minute or two till it runs just water and no air. This will get water to the pump and the heater. This should fix you up.
Posted on Aug 03, 2010
  • 85 Answers
SOURCE: Monarch spa bathe control panel
call your maintenance personnel.
Posted on Feb 02, 2011
My Intex spa turns on heat light comes on ,only for about 2 minutes and then goes out then flashes e96 and is beeping, How do I fix ?
If alarm code E90 is displayed on the control panel, it means no water is flowing through the system. Check the attached troubleshooting guide.
Mar 14, 2016 | Intex Pool & Spa
Pride jazzy 600 power wheelchair controller lights flash
make sure the motors are not disengaged, turn off chair, can you move it by pushing it? if so lock the wheels and try again. next is the controller in lockout. press and hold the on button till it beeps push joystick forward til it beeps pull it back til it beeps turn off try again. you can call 1-800-800-8586 for tech support
Sep 28, 2012 | Pride Mobility Products Pride Jazzy 600
My bestway lay z spa pump and heater unit has stopped working. Three lines flash on the LED panel and all the lights are flashing simultaneously. Non of the buttons work and I have tried re-setting the...
PDF Manual at the link below.
http://www.drinkstuff.com/products/pdf/lay-z-spa-owers-manual.pdf
All lights flashing indicate a fault with the pump.
This is a common fault with these units which the supplier blames on people not following the installation and maintenance instructions.
If you require any further assistance then please just ask.
Aug 01, 2011 | Kitchen Ranges
Hi, My Fisher & Paykel GW609 is showing the following lights when switched on. 3,4,5,7 . The machine continues to beep, but does stop if you open and close the lid. The light sequence remains as...
Hi - one things for sure the lid switch works well, based on your data - theres a problem with the transducer that controls the water level -
Try this - remove 2 screws rear top corners, lay display on the lid, disconnect clear round tube from the controller & blow into it to see if there is any blockages - fit back & try the machine.
UNDER no condition you blow into the the controller end...
If the above works - enjoy otherwise worst case is you may have to replace the controller module.
cheers
Jun 27, 2011 | Washing Machines
Aug 02, 2010 | Pool & Spa
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
My optical in the back turns red when the PS3 turns on, no screen
put a game in put it on standby hook your controller with the usb lead in (red light) press and hold power it will beep ,beep , double beep shutdown by itsself turn it back on it should default back rf
if not do the first instructions again but power back on by holding down again beep, beep, double beep but let go of the button b 4 it shuts down and there will be a dev mode this is something sony dont want you to know if helps give me a tick so to help others
Aug 26, 2009 | Sony Playstation 3 (PS3) Console
Controller not working
I had the same problem, so I called customer service and had me do this:
1) with the USB cable plugged into the controller, power down the ps3 and turn the on/off switch in the back to "off".
2) hold your thumb down on the front button (where you normally can turn it on) while turning the switch on the back to "on" again. keep your thumb or finger on the front switch.
3) You will hear the normal "beep" that you usually hear when the PS3 boots up, but after a few seconds later, you will hear a secondary beep. Remove your thumb or finger after this second beep and the PS3 will reset itself after a few seconds. I have a projector connected to it, so I had to set the display screen back to HDMI afterwards, but when I disconnected the USB cable the controller worked wirelessly again. The customer service rep said that this allowed the controller to pair with the PS3 again. Note: You probably do not have to have the controller plugged into the USB cable at all while doing this. I just happened to have it plugged in. Hope this helps.
Mar 29, 2009 | Sony Wireless Controller for PS3
E1 and F1 flash, with beeps at 15 sec. intervals, & oven not working
crys, the tech sheet for your model states that you need to replace the electronic control (clock) when this error is flashing. Catriver..post back.
Oct 12, 2006 | Roper FGP300 Gas Kitchen Range
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
