Question about Food Mixers
I have a 2011 c713 and my shaft beater is stuck when I try to pull it out for cleaning. What are my options.
3 Suggested Answers
SOURCE: The dough hook is stuck in the beater shaft of kitchenaid mixer
It sounds like it got overloaded when you last mixed dough. It will only come off the way it went on. If it has been bent on, it may need a bit of gentle encouragement.
Posted on Jan 24, 2010
  • 11 Answers
SOURCE: The beater shaft is stuck, can't get the flat
Try some oil... ...or liquid dish detergent on a wet rag and rub around that area..
Posted on Aug 29, 2010
Blade is stuck in shaft of kitchen aid
Get some CRC around the shaft and into the beater hole and wriggle it about until it comes free. Rasp the build up in the beater hole out with a round file and clean up the shaft on the mixer. Remember you are cleaning out the hole not trying to make it bigger than it was. In my experience it is a build up of flour in there bonding itself to the hole in the aluminium beater.
Aug 31, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Stuck beater
The shaft of the beater is bent. After frustrating discussions with Cuisinart customer service, I was able to free my shaft. First, you will notice that the beater screws onto the shaft. Unscrew it. Then, take the nut off the shaft. Next, put a wrench on the shaft that is only slightly larger than the shaft, followed by a washer. Next, screw the nut back onto the shaft. Finally, holding the wrench at the end, hit the wrench close to the shaft with a hammer. If the shaft doesn't come out, hit harder. Since the shaft is bent, you'll need to purchase a new beater.
Feb 08, 2014 | Cuisinart SM-55 Stand Mixer
Beaters are stuck in the mixer
The shaft of the beater is bent. After frustrating discussions with Cuisinart customer service, I was able to free my beater. First, you will notice that the beater screws onto the shaft. Unscrew it. Then, take the nut off the shaft. Next, put a wrench on the shaft that is only slightly larger than the shaft, followed by a washer. Next, screw the nut back onto the shaft. Finally, holding the wrench at the end, hit the wrench close to the shaft with a hammer. If the shaft doesn't come out, hit harder. Since the shaft is bent, you'll need to purchase a new beater.
Dec 24, 2013 | Cuisinart SM-55 Stand Mixer
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
Mixing attachment for stand mixer is stuck
I had this happen today. I took a towel and covered all of the beater except where it attaches. I sprayed WD-40 on it. This loosened it and it came unstuck. Then I washed it thoroughly with hot water and soap. It had some dried batter stuck inside which caused it to stick. Guess I better pay better attention to how clean I get it inside. PS Don't spray WD-40 anywhere else - this is something you make food with!
Mar 28, 2009 | KitchenAid KP2671 Professional 6 Series...
Blade won't release from mixer
Try to push up while you turn the blade. Don't be afraiid to turn hard.
Dec 30, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Can't remove beater from mixer...
I took the advice from: http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=6356
I put a wash cloth in a pot of boiling water and used tongs to wrap it around the beater shaft while the mixer was resting on its side. When the wash cloth was not too hot to touch, I put it back in the boiling water and did it again. I was then able to easily remove the beater.
Nov 28, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
Food Mixers Logo
42 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
