930x started to hammer noise then lights went blank nothing working switched of mains power couple of day switched back on all lights on front panel but will not start up
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Posted on Jul 18, 2007
  • 1226 Answers
SOURCE: Kenmore Elite Dishwasher will not start
Consider examine inside there is maybe fuse busted on the panel or in the circuit through the control panel of the machine.
Posted on Feb 06, 2008
  • 174 Answers
SOURCE: Tomtom 910 trouble shooting - not powering on
Got to the following link to find the reset button and see if a reset resolve your problem.
Posted on Feb 25, 2008
  • 2712 Answers
SOURCE: No Picture
I would check the soldering first for any cracks, and any obvious faulty capacitors or components. It looks like the power board is going into a protective mode because of a short / failed component somewhere.
It would be virtually impossible to guess exactly where with a spot check..
Posted on Oct 29, 2008
  • 5 Answers
SOURCE: Lost all power/electrical when went to restart car, battery fine
I had an old Accord which occasionally wouldn't crank or start, took out the Main Electrics Relay situated up under the dash near the steering wheel, resoldered all the solder joints on started like a rocketship on steroids. Seems the solder joints "evaporate" and "dry out", fresh solder conducts full power.
Posted on Jan 19, 2013
HELP! Olevia lt37hvs screen went blank. No Sound, panel buttons wont work. Backlight is only on on half of screen.
if you had audio i wold say its most likely the Tconn or its upper two connections to the Panel itself. But since you dont have any sound either I would assume its either the LVDS cable from the main board to the Tconn or the Main board itself as audio and video are produced on the main board, You can get replacement boards from
Aug 12, 2012 | Olevia LT37HVS 37 in. LCD HDTV
I have a 94 mitsubishi montero ls. it started making a noise as if it were throwing a front wheel bearing. I pulled over and check the front hubs for heat. None was found. So with hopes it would change...
Possible, but any noise should be investigated fully. Start by checking front diff oil, then transfer case oil. Best to just drain both then look for any metal in oil.
Jul 10, 2011 | 1993 Mitsubishi Montero
I have a HTC 6800 that started acting funny about a week ago. At first the screen got lines across it when I would open the keyboard, then after a couple of days the srceen just froze when the keyboard was...
I had this same problem, there is a thin line of wires connecting the bottom half and top half of the sliders, after awhile it just plain wears out and will generally crack, without these wire anything on the front of your phone will no longer work. The screen is black but stil lights up a little bit and occasionally the buttons light up but its pretty much toast I'm sorry to say. I upgraded to a HTC Touch Pro 2 and am happier than ever!
Jan 18, 2010 | HTC PPC-6800 Smartphone
Motherboard won't boot: no noise, no nothing...
Shorting the two leads will work but don't keep the two wires together. They are not ment to stay connected. Consider replacing your cases ATX power switch. Take a look at the link provided for a new switch;
The green LED on the motherboard means the board is in "Stand by mode". This green LED uses 5V DC to light the LED. After replacing your PS back into your system it may function just fine.
Good luck.
Dec 03, 2009 | Intel Motherboard
My son ps3 stopped working
turn the main power switch off then on(the one on the back) then hold your finger on the I/O button on the front till you get a second beep. This will reset the ps3, if this did not fix the problem then something is broken.
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
Red power light on, making a noise but won't switch on/off
hi dear customer. add fast check the electric power and voltage. latter , cheking jumper on the main board, total main boart opening the cacing out,servising total main board.
Jan 14, 2008 | Packard Bell iMedia 6826 (P481000502) PC...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
