UN40D5005 shows black/white horizontal lines across top 3-4" of display.
My UN40D5005 has been slowly degenerating - it started with an intermittent band of horizontal white lines across the top few inches of the display. It has now gotten bad enough that the top 3-4" of the display are gone - a mix of white and black lines obscures the picture. I assume this is a logic board issue... Any ideas? Thanks.
  • Anonymous Aug 19, 2017
    any luck? this just happen to me today
Mike1963
  • 8 Answers
SOURCE: WHITE LINES
Replaced C407 100uf/35V Vertical section.
Posted on Mar 04, 2008
  • 138 Answers
SOURCE: Dozens of horizontal lines across display!! HELP!!!
Bring up the menu and if the lines are not on the menu replace the small signal board that is your video prossor. If the lines are still the replace the Y main board that contrl the top half of the screen.
Posted on Aug 20, 2008
SOURCE: Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Posted on Nov 09, 2008
  • 231 Answers
SOURCE: Hitachi Plasma very thin bleeding horizontal lines
very possible the YSUS board is going bad .If YSUS is going bad .I would also replace XSUS board since they are same age..Also whenYSUS is replaced make sure you make pot ajdustments as old YSUS and also with XSUS board
Posted on Aug 26, 2009
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Posted on May 23, 2010
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
Hi, samsung un40d5005 led tv horizontal white bar only at top of screen about 3/4 inch wide, fixable?
Hi Gary,
The problem of your TV may be solved by someone who is an expert in fixing the LCD screens. Unfortunately there is nothing you can do yourself.
Oct 09, 2017 | Samsung Televison & Video
Vizio TV has a horizontal 2mm black/multicolor line.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 27, 2016 | Vizio Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Hello, I have a Sony Viao VGNCS215J that is a year...
Sony has identified a limited number of VGN-CS series computers which may display a horizontal line on the LCD screen.
Click here for more details
May 20, 2010 | Sony VAIO VGN-CS215J/W Notebook
LG F700P monitor black out on top half, horizontal white line
Sounds like your monitor or graphics card may be going bad.
Dec 07, 2008 | Computers & Internet
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Feb 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
