Question about Miscellaneous
Hi. I am having wifi issues with a Samsung un60ju7090 tv. Very intermittent. Would be working fine then drop connection. Sometimes searches and finds no networks, or finds networks but can't connect
For about a month turning off and on the tv would fix it but rarely works now. Recently, when going into the contact Samsung area of menu, sometimes the wireless MAC address is blank. If I stretch a Ethernet wire across the room, which I prefer not to do, it always works fine.i friend said it might also be a problem with the"main board", but issue is only with wifi.
    New Friend:
    Problem Solver:
  • 7 Answers
I would update the wireless driver ,if that did not help it may be an antenna issue
Posted on Jun 03, 2017
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 120 Answers
My Samsung TV gets lots of updates. Once in a while an update causes problems. Check your firmware version and make sure it is the latest. Setting the DNS manually also helped. is one of the settings typically used. You may need to do a factory reset as a last resort. It the TV is forgetting settings is sounds like a hardware issue. And make sure the TV air vents are clean and getting good air flow to prevent excessive heat build up.
SOURCE: wireless router dropping then disappeared
I don't know a solution but the router will appear in the list along with neighboring routers but it will disappear and the others will still be there so it's not an adapter problem something in the router stops sending a signal
Posted on May 22, 2007
  • 20 Answers
SOURCE: Dell Laptop with XP keeps dropping connection
find the manufacturer/model # of your wireless adapter and download the latest driver from dell's website (you can go to and enter your service tag/laptop model # if you want).
Posted on Jun 10, 2008
  • 488 Answers
SOURCE: can't find mac address on my acer to connect to wireless network at work
i think the wireless at your work filter computers based on their MAC address as a security measure hence you are unable to connect..
to find your comp's MAC address follow this:
  • From the Start button select Run
  • In the box which appears type cmd and click OK
  • A new windows will appear - at the prompt type ipconfig /all
  • The MAC address will be referred to as the Physical Address and is made up of 12 characters e.g. 00-D1-AB-F2-G3-89
    You will have a separate MAC address for your wireless card and your Ethernet card. Make sure you use the correct one
  • do ask the admin of your work wireless system to add your comp's MAC address so that you are able to connect..
    am no expert but love to help out...hope it helps you...all the best!
    Posted on Oct 28, 2008
    • 1269 Answers
    SOURCE: XBOX 360 not connected to wireless connection on Linskys WAG54G2
    You should enter the "Wireless MAC Address" of the XBOX and not just the "MAC Address". You can see it on the system info of the XBOX settings.
    Posted on Jan 06, 2009
    • 63 Answers
    SOURCE: hp Pavilion dv1000 laptop wireless connection
    you might have to review the driver version of your wireless. try to check if there are updates that might fixed the bug. go to my computer, right click, manage, device manager, network adapters - under it move your mouse on top of the wireless, right click, properties, driver and check driver version and date. then go to your hp pavilion product support
    and look for new version of network wireless driver might have. let me know if this doesnt fix the problem.
    Posted on Apr 15, 2009
    Network issues with Samsung Smart TV UN60JU6500FXZA
    You mention two separate issues, WiFi and smart hub. As you know Samsung built in manual is the worst idea ever. There is no picture of the complete rear panel connection for example.
    If the smart hub is the actual WiFi antenna then if your system doesn't recognize Smart Hub then you have a bad smart hub.
    to test smart hub plug something into hub ( DVD HDMI, video game) If your remote has smart hub button press and see what appears. Otherwise select source on remote see if your attached item appears. (That would indicate smart hub does talk to TV)!
    Since you can access your network when hard wired your network password is stored.
    Once you have verified Smart Hub is functional then work on WiFi.
    i will say my Samsung is 3 ft from my router and hard wired for better streaming speed.
    I use Bluetooth access to share photos from IPads.
    I would leave TV hard wired.
    Sep 20, 2016 | Samsung Televison & Video
    Hi, I have a bush smart TV which came with a dongle. We have very fast internet speeds. When we go on Netflix etc it connects fine but after about 30 mins or so the connection becomes delayed and...
    A dongle... There's your problems right there as to why the internet is lacking. Look on your tv for an ethernet port or check in the tv menu for a wifi option.
    wifi will be easy and no cords, but wired with an Ethernet cable sometimes brings better speed and more reliability..
    Dec 31, 2014 | Video Game Consoles & Games
    TV goes off suddenly. Searching for connection.
    'Searching for connection' sounds like it's looking for a network link. check your internet connection. If it's supposed to be watching cable or broadcast TV, check the setup menu.
    Oct 21, 2014 | LG 37LH40 37 in. LCD HDTV
    Only one device is having internet issues
    Have you checked the IP settings on your internal network. It sounds like you have 2 identical IP numbers.
    May 29, 2017 | D-Link DIR-615 Wireless Router
    Samsung 55" turns ON/OFF by itself and will not connect to wifi network
    I have the same issue. I read and watched online tutorials about the compositors but after opening the set up I was unable to find any that had gone bad. I was able to upgrade the software by using a USB thumb drive but the issues are still there. I'm thinking of swapping out the motherboard and/or the power board next to see what the fix is.
    Feb 24, 2013 | Samsung UN55ES7100 55" Class Smart TV 3D...
    My cellphone is samsung corbe 3653,,i can search a wifi and im connected but the problem is when im able to start interneting it is DNS failed?how can i open that dNS/
    Hi! Welcome to FixYa
    This sometimes happens in Samsung Cellphones that while connecting to internet via WIFI, DNS failed
    To solved it follow the given procedure:
    • Go to browser
    • Then go to setting
    • Then clear cache, empty cookies and delete history
    • Now restart your Samsung S3650 Corby cellphone, then connect to desire wifi connection, then browse after setting up your browser profile
    If it doesn't solved then contact to Samsung Service providers and consult with providers of WIFI connection, But i hope it will work.
    Thank you for using FixYa
    Mar 29, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
    "Voice input" for texting and "Voice search" wont
    Virgin mobile internet is down at the moment (11-12). That's probably the issue. Now word on when it will be back up.
    Nov 12, 2010 | Samsung Cell Phones
    I have a HP G70 with an Atheros AR5009 WiFi adapter. I use an Apple Time Machine/Wireless router. My Macs stay connected to the router with no problem. My HP drops multiple times a day. All drivers are...
    Hi, did you get this problem resolved? I am having the same issues but cannot seem to find anything to resolve. I have a hp g70 running vista. Sometimes the connection can be stable for hours but then other times it disconnects every few minutes. I know the router is working fine as I have 2 other laptops that never drop the connection and my ps3 and phone always stay connected as well. Thinking now that I have got to take it back
    Feb 07, 2010 | HP G70-250us Notebook
    Samsung HLP5063W-Picture Dropping Out Using HDMI
    is the eprom settings set correctly for the input beeing used,you must enter the service mode to inspect and adjust the settings,call your local dealer for assistance.
    Sep 12, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
    Miscellaneous Logo
    Top Miscellaneous Experts
    Andy Fraser
    Andy Fraser
    steve cannon
    Level 1 Expert
    Dan Grod
    Level 1 Expert
    Are you a Miscellaneous Expert? Answer questions, earn points and help others
