Question about Pentair Minimax NT Heater
The thermal fuse in my Raypak 105B pool heater keeps blowing.
Any suggestions on why the fuse would blow again after 1 days use?
    President:
  • Pentair Master
  • 1,378 Answers
The thermal fuse react to rollout flames from the burner. Whatever caused your first one to fail caused the second and will continue to be a problem until fixed.
You could have a clogged up heat exchanger from soot and/or debris. You can also have problems with clogged burner tubes.
Finally, you could simply have wind issues that would require a high wind stack being installed on the heater to correct.
Posted on Jul 26, 2009
How to winterize a raypak pol heater
blow out with air then antifreeze (RV antifreeze red stuff)
Aug 27, 2013 | Raypak 266A Digital Cupro-Nickel Natural...
Jandy Aquilink control panel keeps tripping circuit breaker
turn off heater if it still happens mark all auxs remove all then try again if it doesnt blow fuse plug 1 in at a time until it does thats whrer your problem is
Aug 16, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
BLOWING FUSE IN CONTROL PANEL
if not ignitor shorted maybe blower motor bad
Jun 10, 2012 | Hayward Heatpro 81k Btu Swimming Pool Heat...
Blows thermal fuse on raypack heater?
If you are talking about the "Roll out sensor" located on the lower left hand side, you have a problem with ventilation..Soot,debris, or possibly a rodent nest on the heat exchanger (Located just under the top cover of the heater). If it is electrical, you may have a bare wire touching the heaters housing (somewhere inside) causing a short. Rodents love to chew the insulation off low voltage wiring.
Oct 08, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Back flare on Raypak pool heater
You will need to pull the burner tray out and clean and blow out the burners. Then you will need to pull the orfaces from the gas manifold and clean each one and blow out the gas line. Then with a mirror you will need to check the fire brick inside the burner box. Then you will need to replace anything that is damaged. Good luck.
May 15, 2010 | Raypak 130,000 BTU Propane Gas Pool...
Pentair Minimax NT Heater Logo
526 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
