Question about Mercury Marine 15hp 4 Stroke Outboard, 115lb., 15" Shaft Length,
Parsun 15hp has,nt got a spark ,got new cdi ,regulater still no spark please help
    Sergeant:
  • 201 Answers
It could be the stator assembly or the coil leading to the spark-plug.
Posted on May 16, 2017
Testimonial: "ThAnks for your help"
Wiring diagram for 3.6HP parsun outboard motor 2 stroke please
sorry but here in US never heard of that Make.
Oct 31, 2014 | Boating
Cdi box no spark with new box
sounds like yoar stator plate klean yoar ponts that shold do it and chek yoar points
Jan 25, 2014 | Honda Motorcycles
OW TO CHECK AN ELECTRONIC PICKUP ON A 40 HP PARSUN OUTBOARD MOTOR T40 FW
So it starts when you spray Carb cleaner into the Carb? Then your Carb needs to be cleanred
Apr 11, 2013 | Boating
The CDI does'nt give electricity going to sparkplug. Do I need to know the diagram for troubleshoot CDI? can I see the diagram?
If there is power into CDI but not out to coil then check that kill switch works, also check side-stand switch If OK & coils are earthed then get CDI repaired
Jan 10, 2012 | Yamaha Motorcycles
Hi i have a dinli 100cc quad bike .the quad will nt start and there is no ignition i have checked the spark plug so can you help me if you can i will be very happy
I assume that is a 100cc, 2 stroke ATV? If the starter motor is spinning, and you just don't have any spark. First, replace the spark plug. If that doesn't fix it, then you may have one of the following problems: Bad CDI, Kill Switch or Rip Cord Shut off switch, Frayed wire shorting out, cracked/damaged spark plug cap, bad coil or coil wire, bad stator. My bet is on the kill switch and/or Lanyard/Rip Cord shut off switch or the CDI. You can bypass your shutoff switches to see if they are the problem by either disconnecting the wires or connecting them together(depending on the type of system you have). CDI's routinely fail on small engines and generally cost about $20-$70, depending on the style. www.solanocycle.com
Jan 02, 2011 | Derbi Cross city Motorcycles
I got weak spark so wont start got new plug
sounds like oxidization on your timing plate take it out and clean it with a peice of sand paper
Mar 18, 2010 | 2001 Honda NSR 125 R
Not gettig spark on honda cbr 600 1994
iF YOU ARE NOT GETTING A SPARK ON ANY CYLINDER THEN
1 CHECK FOR POWER TO COILS WITH A METER
IF NONE THEN SUSPECT :- THE IGNITION FUSE - VISUALLY CHECK THE WIRING - A BAD CONNECTION IN THE IGNITION CIRCUIT - THE KILL OR SIDESTAND OR CLUTCH SWITCH, OR EVEN THE IGNITION SWITCH.
2 IF THERE IS POWER THEN SUSPECT THE PICK-UP (PULSAR) COILS & WIRING FROM THERE TO THE CDI - & LASTLY BY A PROCESS OF ELIMINATION SUSPECT THE CDI (ITS GENERALLY IMPOSSIBLE TO CHECK THE CDI APART FROM VISUALLY & BY REPLACEMENT)
I HOPE THIS HELPS, IF SO PLEASE MARK AS USEFUL
RIDE-SAFE
BIKE-DOC
Jan 07, 2010 | 1994 Honda CBR 600 F(2)R
My 2004 Honda Shadow will not start. I have changed the spark plugs, wires, ingnition coils and now I'm left with the CDI module. The bike turns over but no spark. Is there a way to test it before I buy a...
I would get a test light and check if i had power to my coil and to my cdi module .You more than likely lost powerto one of them .those cdi last for every. check your switch make sure you got power there to. Hope this help
Feb 21, 2009 | 1989 Honda VT 1100 C Shadow
Mercury Marine 15hp 4 Stroke Outboard, 115lb., 15" Shaft Length, Logo
108 people viewed this question
Top Mercury Marine Boating Experts
Fabrice Wolters
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Mercury Marine Boating Expert? Answer questions, earn points and help others
