After cleaning keyboard it wont type anything at all I just used damp cloth hardly dsmp at all just enough to get finger print off please help
Vish2
  • 74 Answers
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Either the heater element is breaking or is loose and getting only 110V instead of 240V.  First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2.  Also check the connections and continuity for the heater element.
Posted on Oct 11, 2007
IB4G2008
  • 3587 Answers
SOURCE: mouse pad wont work after water spill
not difficult..with right tools and patience..the touchpad is part of the upper assembly, and requires that the bottom be removed. When I do this, it takes around an hour.
got backup?
Posted on Feb 20, 2008
  • 85 Answers
SOURCE: Clothes not drying even after 4 cycles
you have to check your dyer vent hose and vent pipe to outside for any restrictions. #1 problem for extented drying time. it like having a backed up sink
Posted on Dec 16, 2008
CMV9
  • 594 Answers
SOURCE: Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Posted on Jan 08, 2009
  • 106 Answers
SOURCE: damp clothes at end of spin cycle
Time to check out and clean your filter...........
Posted on Mar 01, 2009
I cleaned my keyboard with a slightly damp cloth and now after reboot i cannot type anything, have i killed it??
Seems like your keyboard might have gone so you can order a online a replacment keyboard to fix it yourself or better take it to some hardware shop to get this thing fixed.
Nov 01, 2013 | Packard Bell Easy One Silver 2101 Notebook
Tip
PC Tools- How to clean your computer
  • Cleaning the Computer
If you've noticed that your computer's keyboard feels sticky or the monitor screen appears spotted under the light, it's time to clean these pieces before internal damage occurs. Cleaning your computer's keyboard does not require special knowledge or skill. But you should take precautions to avoid damaging the internal parts when caring for the external hardware.mike_alozie_0.gif
1. Unplug the computer and all accessories before getting started. Anytime you attempt to clean an electric appliance it is important to disconnect the power source to reduce the risk of electrocution or shock. After unplugging the keyboard and monitor, along with any accessories that may be plugged in, use a damp clean cloth to wipe all the cords that are connected to the monitor and keyboard and remove dust balls or hair, along with anything else that might cling to them.
2. Move the computer monitor and keypad to one side of the desk and wipe the area clean where the equipment usually sits. Be sure to wipe a large parameter around the monitor area and let it air dry completely before returning the keypad to that area. You might want to use a clean towel or dry cloth to rub over the desk to be certain it is dry, as dampness can damage the machinery or cause it to stick to the table's surface.
3. Rinse the damp cloth in clear hot water and wring it nearly dry. Gently wipe the monitor screen, including all the corners, to remove dust and spots. Then wipe the surrounding areas and framework of the monitor, including the indicator lights that show when the system is operating. Don't forget the back of the monitor as well. If you have a laptop computer with a top that folds down and closes, wipe the hinges carefully, using a cotton swab for grooves and the latch. Check the latch to see if it is sticky or closes readily.
4. Next, go over the keyboard with the cloth, lightly rubbing around each key and button. Wipe around the sides of the keyboard, catching the off and on switch and CD player. Then use a cotton swab to ease around the edges of each key and row to retrieve minute amounts of dust and crumbs. Carefully clean around the lights, plug openings, and speakers, as well as other areas of your computer. Check to be sure you are not leaving wet traces on the equipment, as this means your cloth is too damp and should be wrung out more.
5. Allow the machinery to air dry, or use a soft cloth to pat the keyboard and monitor dry. Don't use fabric with lint or that is tough enough to scratch the screen. Reassemble all the cords and parts when you are sure the entire unit is clean and dry.
Plan to clean the keyboard and monitor every month or two. You may want to schedule maintenance for an interior cleaning once or twice a year. A clean computer is more likely to work well and last longer.
on Apr 25, 2011 | Computers & Internet
How to clean a toshiba tz50v51 screen
DO NOT USE under any circumstances a chemical cleaner on the panel. This will damage the screen. If you have finger prints on the screen, use a damp, and wring it out good, non abrasive cloth. Then slightly use pressure just enough to remove the fingerprints. Then dry with a non abrasive cloth using very little pressure.
Apr 03, 2011 | Toshiba Televison & Video
When the printer prints out a typed document there's black lines in the background that are pretty dark wherever there is typing. I don't know what is wrong
You most likely have some build up dirt on the bottom of the print head. If you can take the print head out do so and clean the bottom with a damp cloth. If you can't get it out take a damp cloth and get the print head to the middle of it's run and unplug printer then get the damp cloth under the print and do a side to side motion to clean the bottom of the print head.
Feb 11, 2011 | Dell A960 All-In-One InkJet Printer
My second row of keys on the keyboard will not work; ii typing with the on screen keyboard and the keys asdfjkl;' and Enter keys are not working. i did not drop or spill anything they all just stopped...
The issue could be with many cause. In order to isolate this issue I request you to perform the below steps :
====================CLEANING KEYBOARD============
To get started, find a soft, lint-free cloth and some window cleaner like Windex. Turn laptop upside down and give it a gentle shake. This will clear out dust and debris that has fallen in between the keys. If your vacuum has a soft brush attachment, you can vacuum the keyboard gently, too.
Now, spray a tiny bit of Windex on your cloth. You do not want it wet, just barely damp.
Gently scrub all the areas around the keys of your keyboard. Watch for an excess fluid squeezing out of your cloth. Should this happen, dab it up quickly.
Once the housing for the keys is cleaned, focus on cleaning the keys themselves. Gently stroke the keys with the barely damp cloth, repeating strokes until each key is cleaned.
Badly soiled keys can be (try and if are not difficult to pull them out do not attempt) pried off the board, cleaned and snapped back into place.
You can clean crevices by wrapping your cloth over a table knife and carefully and gently running it between keys. Do not push down into the mechanisms below the keys, though.
Once you have cleaned the keyboard to your satisfaction, let it set to dry for half an hour, just in case it is damp.
Also note that office supply stores sell cans of air. It's not just air; it's air that comes out of the can with enough pressure to push dust out of places it shouldn't be. The cans come with little straw-like tubes that you can attach to the sprayer so that you can get inside your removable drives and between the keys of your keyboard.
*** Uninstall and reinstall Device drivers from Device Manager ***
1. Click Start, type Device Manager in search field.
2. Click on Device Manager.
3. Click "+" beside Keyboards Device Category.
4. Right-click the listed Keyboard and select Uninstall.
5. Restart the system.
Windows will redetect the device on restart and reinstalls the drivers automatically.
May 14, 2010 | HP G60-235DX Notebook
Cleaning the fingers prints, etc off the screen.
Don't use anything with alcohol a lite damp cloth is all very soft one at that. do not rub hard you may damage the surface.
Apr 30, 2010 | Toshiba 42H81 42" Rear Projection...
I am getting an error msg "U052" and I am using original canon ink cartridges and I cannot pring anything. . .
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
Aug 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Samsung LCD screen cleaning technique
Hard crusties? what do you do to have this type of matter on the screen?
Be carful with what you use on the screen, a damp cloth is permissable. This does not mean spraying liquid directly on the screen and wiping it
Spray into the cloth or dampen cloth and wring out well. Do not let any excess water drip down the screen especially if it gets into the TV via the outer frame around the screen.otherwise poof it will never work again
please rate our help to keep the service online
Aug 18, 2009 | Televison & Video
Printer will not print anything
PREM
Feb 20, 2009 | HP Deskjet D4260 Printer
Cleaning Laptop
You can buy specialist screen cleaning wipes (but I don't know if you can get them in Kuwait), otherwise a damp cloth should do the trick just fine.
Avoid using everyday cleaning chemicals or anything abrasive.
Matt
Feb 29, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
k24674
jasbo
jasbo
