Question about Sharp Televison & Video
I have a sharp lc-60eq10u. The screen did come on with audio but black horizontal bars flashing on screen. Now quit completely and is flashing codes on standby light. 3 long and 1 short blink. Help
SOURCE: Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Posted on Feb 06, 2008
Slinteriors
  • 8617 Answers
SOURCE: green light blinking
It will have to be diagnosed. As the only blinking light error for that model is when the led turns from green to flashing red which indicates a lamp error. If its new I recomend returning it most retailors will freely exchange a new TV . Wish I could help more but there is no diagnostic codes for that model other than lamp error. And being that I am taking that the back light isnt working either. I would contact the retailor without delay.
Posted on Apr 11, 2008
  • 8457 Answers
SOURCE: Sharp AQUOS LC-26P50E television. Stuck on 'Standby'/'Sleep'
Ur power ic inverter board is dead.
U need a new one.This prob.very comon with SharpThe Sharp corp. is a joke,never release much of this part for sale.It almost imposible to find it.
Posted on Sep 05, 2009
  • 8457 Answers
SOURCE: sharp lc-46d64u blinking codes. power blinks 3
Very common in Sharp,tries unplug,replug back in,tries again off/on couple times,still happen blinks than ur main video board it dead.
Posted on Nov 12, 2009
  • 7 Answers
SOURCE: line accross top of the screen with flashing black and white boxes
Go to menu and settings and look for OVERSCAN and set this to on and hey presto no more white lines no matter what ratio your in.
Posted on Dec 31, 2009
My sharp aquos is having problems with the picture. It gets lines across the screen and then the picture goes dark and it goes off. The power light blinks 5 fast 2 slow repeatedly. Any ideas?
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 02, 2017 | Sharp Televison & Video
Have a Sharp aquos that has a black ghosting all over the screen and menus. The screen seems to jump as well. So it is no individual source. The model # is a Sharp LC-60EQ10U
The TCON Board or the LCD panel is Faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 19, 2016 | Sharp Televison & Video
Sharp aquos 60 in smart tv lc 60eq10u need help with picture settings
Refer its user manual for details. www.retrevo.com/
Try this site to download the user manual for free. Electro help
Oct 23, 2014 | Televison & Video
Sharp aquos LC-60LE640U flashing error code 2-5.
Dont buy a Sharp. Buy a Sony, Panasonic, JVC, Visio, ANYTHING but sharp!
Jan 27, 2013 | Sharp LC-60LE640U 60 Inch 1080p 120Hz LED...
How to connect sharp HT-SB350 to Sharp LC-42D69U
You may have to use the optical cable connections. Make sure there is an optical out on the tv and on the sound bar. Get an optical cable to connect them and go to the audio setup screen and direct the sound from internal speakers to optical out.
Nov 13, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Black horizontal line, red parallel vertical lines
REPLACED LCD PANEL
Manufacturer Sharp Part Number RF-R1LK420D3LF2 Description 42" WIDE LCD PNL -
Sep 28, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LC-32D6U GETTING NO SOUND
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (rubbing alcohol works quite well). Despite what the images say,
YOU MUST REMOVE ALL BLACK RESIDUE FROM BOARD. IT WILL NOT WORK IF ALL THE RESIDUE IS NOT REMOVED.
This kit is Sharp Part Number: PSPKIT663WJZZ and is available from Partstore.com for $19.95. http://www.partstore.com/Part/Sharp/Sharp/PSPKIT663WJZZ/New.aspx
It’s possible to get the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. http://www.partstore.com/PartSearch.aspx?PartNumber=PSPAZA663WJKZ&hiddenInputToUpdateATBuffer_CommonToolkitScripts=1&x=26&y=14
Jun 21, 2009 | Sharp LC-26D4U 26 in. LCD Television
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Horizontal black line running through tv
You need to take it back to the place of purchase.It has a bad panel.I don't know why the other person didn't answer this is a easy one.
Dec 08, 2007 | Sharp LC-46D64U 46 in. LCD HDTV
Sharp Aquos 37 inch LCD HDTV - black trails on picture when hot
LCD LAG COMPENSATION CIRCUIT? never heard of that, dosent mean it dosent exist, you may have a LCD driver board issue, never seen the trails thing on Aquos, have had to update the software on many of these critters though.
Jul 07, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
49 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
