Question about Refrigerators
All the fuses are new all other dc products work, the fridge won't turn on in any of the settings where should I start trouble shooting
3 Suggested Answers
  • 2926 Answers
SOURCE: won't start - will crank but won't fire
If the relay is working fine and you checked it the correct way, then there is a blown fuse or a bad connection in the circuit with either the positive side or negative side of the circuit in the harness.
Posted on Jul 25, 2011
saailer
  • 1871 Answers
SOURCE: My turn signal fuse blew
Hello! The Purple/Orange wire that runs from the fuse (#8) to the Turn signal flasher before it passes through the flasher and goes to the multi function switch Is grounded; either resistively or solid...If you have a multimeter and a wee bit of experience using it set it on the X10 ohm scale...Turn key off...Pull the fuse that blows...I believe #8...Read from the fuse side that connects to the Purple/Orange wire to ground...If you read to ground; Pull the flasher out and read again...If the ground remains with the flasher out the wire is grounded somewhere along the harness...If the ground goes away when you pull the flasher then the flasher is defective (not my first choice)...The best way to repair is to run a new wire from the fuse to the flasher and cut the Purple/Orange out...
Take this a step at a time and let me know what you find...Guru.............Saailer
Posted on Aug 29, 2011
It will not turn on.
First thing, disconnect AC and DC power. You can leave the LP attached but go ahead and close the valve for now.
Plug in AC only and let it boot up. If the fridge does not automatically, press the power button to turn it on. The refrigerator should start working. Let it run for a while to make sure it does get cold. Once you confirm it does work you can either unplug the fridge or just open the breaker in the fuse panel.
Before you reconnect the DC wires, you need to check the power coming in. Most camper units will have wiring that will have color on one side and white on the other. The color wire will be your 12VDC, white is neutral return. Once verified, pull out the fuse for the power to the fridge to isolate the DC voltage. Check with the manual for the fridge, the positive input should be marked or identified in some manner. Open the valve to let LP back into the lines and wait a few minutes. Plug the fuse back in. If the fridge does not turn on automatically, press the power button to turn it on.
With the DC power on and no AC detected, the display should display CHECK. Let the fridge run for a bit to make sure it cools. Once you know it is working, the breaker for the AC can be closed to turn on the AC power to the fridge. Press the MODE button until AUTO displays displays.
Let it get cold and resume normal operations.
May 10, 2016 | Atwood 6 Cubic Ft RV Refrigerator Black...
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
Hi...recently purchased a 2005 Roadtrek RV with a Dometic RM 2354 fridge in it...was getting things ready for camping and had the RV hooked up to 110 power...pushed on button for fridge and went through...
You said there was NO lights on the unit. The Dometic service manual says:
1. No operation - no panel lights: DC Volts
Fuse
Wiring
Upper Circuit Board
Lower Circuit Board
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
I would start with the DC volatage and track it back until you lose it. Most of the time it does end up being the lower circuit board though.
Aug 03, 2011 | Dometic RM2652 Refrigerator
Won't start - will crank but won't fire New coil pack, new battery,- trouble shooting code P1389 - checked ASD relay - working fine
Jul 23, 2011 | 1999 Jeep Grand Cherokee
We can't get our Dometic fridge to light when it's turned to gas. Model number 2453. It works on AC and DC but just won't light at all on gas. The gas will light but won't stay lit in the...
If you are lighting the pilot corectly and waiting for the thermo couple to warm up and then setting it to on, then the thermo couple is probably bad. Good luck!
Jun 27, 2011 | Refrigerators
My SX30 IS turn on automatically while inside the box then just "die" down. As a result, the lens stuck up and the camera won't power up. My solution is re-charge the battery and it turns...
Hiof course not. you have a problem camera. like the type of problem it could involve several circuit trouble shoot. First power control pcb (dc/dc convertor), on/off control switch fpc, and main pcb. I suggest you to send canonUSA or your local repair shop. ( That must be under warrenty, it is pretty new product) Both place would take time in those type of problem. CanonUSA 2 to 3 week usuallly, local 1 to many week depand on what they want to repair.
Jun 02, 2011 | Canon PowerShot SX30 IS Digital Camera
Just bought a used 1987 Real-Lite truck camper. The roof air unit is Dometic as well as the LP/AC refrigerator. When turned to "cool" the air conditioner really draws down, dims the lights, and eventually...
To start with, if it's plugged in to a 15 amp breaker, and extension cord, the compressor starting up may just be enough to trip the breaker. It will draw close to 15 amps on start-up of compressor, and if there is a light extension cord used to plug it in, that only makes it worse. Make sure you shut all other breakers off in panel except AC, and try it. If you have water heater on hydro, fridge on hydro, and then try to start AC compressor, you'll be way over the 15 amps, especially if it's a light extension cord.
Keep in mind, in order for fridge to work, you need 12 volts DC (Battery) power going to back of fridge. If the controls aren't lighting up at top, you've most likely got no 12 Volt DC power going to fridge. Check all fuses as well.
Jun 02, 2010 | Dometic Rooftop RV Air Conditioner
Dometic refrigerator RM 2652 is not working
The fridge needs a 12 volt DC source to operate properly, which should be connected at the back of the fridge, outside behind cover. Check all fuses in your fuse panel as well. The upper controls are powered by 12 volt DC system, and that's what tells the fridge what to do.. (battery or converter)
May 08, 2010 | Dometic RM2852 Refrigerator
Problem with the electric on fridge not working
Hello Paintinfool3,
I have worked on these in the DISTANT past...
They are a great CLASSIC design... Working on gas
means you are 90 to 95% all good
The electric comprises two basic elements
only confused because you have both AC & DC modes.
Just for simplicity sake the ELECTRIC section
(heater & thermostat) section in the BELOW begins
with SECTION 63...
You need a volt-meter with an OHM scale...
(the $9 kind... HARBORFRIEGHT gives away).
There is a yes/no trouble shooting guide.
Also CUSTOMER CONTACT numbers in the very back.
Phone TECH Support at ... 1 (219) 463-4858
Happy hunting!!
http://www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Support Dometic Mobile living made easy
Carnac the Magnificent
Apr 12, 2017 | Dometic RM2620 Refrigerator
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
