Question about Mitsubishi Televison & Video
I have a Mitsubishi tv model wd-82738 that is blinking green and wont turn on they told me it had to be reset but i dot have a remote for it and i have no clue where the reset button is located
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
SOURCE: Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Posted on Nov 24, 2007
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
SOURCE: Green Light on Mitsubishi WD-62525 keeps blinking
Fluke solution: Press and hold Menu+Enter on front of TV...
WD-62525: My Green Blinking Fix!!!
http://www.avsforum.com/avs-vb/showthread.php?s=eb9ba9017a86fd9993de5feb77ee5f25&p=17646001#post17646001
Posted on Feb 09, 2010
SOURCE: Mitsubishi Model WD-52725 timer green light blinking fast
My Mitsubishi WD52725 will not turn on...the timer light is blinking. We pushed the reset button, unplugged tv. Just got off the phone with Mitsubishi customer "service." After answering numerous personal questions, and being on hold for several minutes, I was told that the only solution was to push the reset button. Duh! We'd done that several times with no change, which is why I called them! BIG WASTE OF TIME!!!!
Posted on Jun 19, 2010
My Mitsubishi WD-82738 dlp tv turns off after a minute
You have a power supply issue that needs to be addressed.
Mar 04, 2016 | Mitsubishi WD-82738 DLP TV
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
How do i change my fornat/resolution on my model wd-82738 tv
See page 6 (this is a display & basic explanation of your transmitter) of the owners manual http://mitsubishi-tv.com/asset/file/basic_owners_guide/738-838_BIB_v3.pdf
there is a format button on you remote transmitter. If you have other format issues it is probably your source & not the TV. You may have to change the source format in which case you will need that mfr. operating manual.
Apr 23, 2015 | Mitsubishi WD-82738 DLP TV
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
Wd-73737 wont turn on blinking green light
First is if you are able to get it to turn on and blue screen only appears it will shut down as no signal noted.
If you can get it on with Mitsubishi remote : Menu, 1,2,3 enter
This is the soft reset and the set also has a hard reset.
Try the soft reset first and let me know what happens.
Mar 09, 2012 | Mitsubishi WS-55613 55" Rear Projection...
TV (wd-82738) shuts down unexpectedly and fast flashing green light comes on This occurs about once a week.
The tv flashing green light is on it have a word"LAMP"writing on the tv frame?Yes,than the tv projection lamp life it is ending.Tv unexpectedly shutdown the tv also have clicking noises sound too?That the board call the Ballast board is dying too,this board only job are only to ignite the projection lamp only.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp and might have also have to replaced the Ballast board too.
Apr 13, 2011 | Mitsubishi WD-82738 DLP TV
Nov 08, 2008 | Mitsubishi WD-52725 52". Rear Projection...
WD-62725 Need to reset to start
Good Day;
When TV will not turn on press the menu & input buttons on TV's panel, hold for 5 seconds. Count the blinks, eg; blinks 2 then pauses then blinks again. It should do this 3 times.l With that information respond back.Or the d-board is bad.
Good Luck.
Apr 21, 2008 | Mitsubishi WD-62725 62" Rear Projection...
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Open Questions:
Televison & Video Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
