Question about Carrier Heating & Cooling
User guides for 8000TS gas "weather maker furnace" with hand held Carrier thermostat
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
Are you looking for sequence of operation?
Posted on Sep 20, 2017
4 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: Carrier Weather Maker 8000 with 88,000 btu natural
Hi, You say that it will light and then shut-off when the ELECTRIC pilot shuts off? If it has an automatic pilot ignition, it wouldn't have a thermocouple? It would have an ignition module with a flame sensor. Could you check this for me and let me know which one you have for sure? I can help you out better if I knew. Thank you and please get back to me.
Sincerely, Shastalaker7
Ps If it is electronic, there will be a flame sensor mounted next to the pilot. It has a ceramic body with a metal rod coming from the end.You can take a piece of steel wool not sand paper and clean the metal rod (sensor). The pilot flame will surround this keeping the burners on.After cleaning it, and if the pilot continues to go out, I would say that you're ignition module has an intermittent internal problem, and needs to be changed.
Posted on Oct 31, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
Posted on Dec 01, 2009
  • 413 Answers
SOURCE: Carrier 8000TS -Thermostat works, fan
If the ignitor does not glow, and you have had it checked, your circuit board could be faulty.
Posted on Apr 14, 2011
I have a carrier debonair 450 it is blank and not working it does not take batteries. needing help
Carrier Thermostat 33CS450-01 User's Guide ...
homeappliance.manualsonline.com > ... > Carrier Thermostat
Appliance manuals and free pdf instructions. Find the user ... Carrier 33CS450-01 Thermostat User Manual. Page 1 ... Carrier Corporation 04/06. Use with most ...
Sep 10, 2015 | Home
My blower on my carrier furnace unit won't turn off? a/c or heater doen't turn on.
gas furnace??? check the start capacitor, put unit in ac mode and see if fan comes on(switch fan to on at thermostat) if it does not a fan problem or capacitor problem. when in cooling mode thermostat controls fan, when in heating mode, furnace controls fan
Feb 18, 2015 | Carrier Heating & Cooling
Code 24 on carrier weathermaker 8000ts
Turn power off to unit. Open air handler and take a picture of the low voltage (tstat) wires and where they are landed. Remove all thermostat wires from control board. Then replace the 5 amp fuse that is likely on the board. Fuse likely looks like one for a car (blade style). Put a jumper (small piece of wire) from the R terminal to the G terminal and turn power back on to unit. This should bring on the indoor blower. Let me know how that goes!!
May 12, 2017 | Heating & Cooling
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Sometimes this can be caused by a dusty control board.
Inspect flame sensor, (located in burner area, opposite side of hot surface ignitor). If the tip of sensor have a white carbon build up on it, it needs to be removed and cleaned, Good luck.
Oct 06, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Inducer Fan Seems To Be Rattling
what make of furnace check for birds and blockage
unfortunatley when they go there gone the squirrel cage wheel will not come of shaft u will need motor n wheel or a "plug n play housing all in one"
Oct 05, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
Carrier Weathermaker won't stay running
Is this a gas furnace if so is it high efficient if so is there an led light on the furnace blinking a code usually seen through a window at the furnace. is the thermostat battery operated if so is it a new battery and are the aif filters new. These would be my first steps to check hope this helps
Dec 21, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Gas not coming on Carrier Weather Maker 8000
either the gas valve is not opening or your not getting gas to the furnace.  also the gas valve won't open unless the draft motor comes on.  if the ignitor is trying to light, but there's no gas, it might be a bad gas valve. i would call your closest NATE certified contractor
Nov 12, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Dec 06, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
