Question about Dryers
I can control fan but not light on wall and nothing on hand remote.Codes on both r down and replaced batteries!any suggestions
SOURCE: ceiling fan
hi you have a problem with your fan do you have the remot book how to operate the fan remote we lost the booklet for the instruction maybe you can send me a copy of your booklet instruction for the fan is your fan is from the compagny home collection and the brend or model tampa thank you
Posted on Nov 25, 2007
  • 157 Answers
SOURCE: hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
  • 239 Answers
SOURCE: fan and remote not working
make sure the main switch is on ,also the chain switch on ,before using control remote!!
Posted on Jan 04, 2009
  • 37 Answers
SOURCE: Have a Hampton Bay ceiling fan that doesn't work.
I'm pretty sure that home depot does sell remotes for that brand, although you may have to buy a new receiver to go with it. Otherwise try a lighting store near where you live. They seem to be able to order things like that.
Posted on Jan 24, 2009
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
Honeywell Marston Ceiling Fan. Why has remote stopped turning the light off?
Dwayne, Try a new battery in remote, if that does not fix, replace your remote, replacements can be found at the larger hardware stores, eg. home depot, lowes,etc.
Apr 03, 2016 | Dryers
Minka aire wall control not working
It comes with a hand held remote. Unless you have the compatible wall transmitter, you'll only be able to use the hand-held remote. The switch on the wall has to be on for the remote to work.
Dec 14, 2013 | Minka Concept II Ceiling Fan
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
We purchased a house that is more than 10 years old. The ceiling fan w/light does not turn on with the wireless remote that is attached to the wall and there is not other switch but this one to turn it on....
You need to know if there is power to the fixture. If there is , then you might need to replace the receiver. It should be under the canopy where the power is connected for the fan.
Sep 01, 2011 | Hunter Ceiling Fan Light Remote Control
Ceiling fan is all wired up and on ceiling but light doesn't come on or fan doesn't spin. I have checked connections and tested for power. Is there a switch or anything on receiver that needs to be...
Jerry, from what you said, I assume you have a remote controlled ceiling fan. If that's the case, check the batteries in the hand held and the receiver, to make sure they are charged. Also, make sure they are installed properly. The Owner's Manual should have a reference to setting or resetting the codes for the remote control (Hand Held & the Receiver). Check those to make sure they are matching. And don't forget, the wall switch must remain ON for the fan to work, even with the remote control. The remote simply overrides the wall switch, when in operation. You may have to use the pull chain to start the fan motor the first time, then the remote can take over from there.
Good luck. I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 10, 2011 | Heating & Cooling
I don't know what model my fan is, but it's only 3 years old and suddenly two days ago the light and fan quit working. We replaced the light switch on the wall-nothing. Took apart whatwe could of the fan...
That may be, because you were using the Remote Control to operate it, but then turned off the wall switch instead of turning it off using the Remote Control.
Turn the wall switch back On and try to get the Remote Control to take back over the operation. If that solves your problem, in the future you will know to turn off the fan and lights with the remote, before turning off the wall switch.
Hope this helps solve your problem. My wife had to learn the same way with ours.
Feb 04, 2011 | Hampton Bay Heating & Cooling
A light bulb in my ceiling fan burned out the other night when I turned it on with the remote. I changed the bulb, but since then the remote will not turn the light on or off. The wall switch will, and...
Sometimes all you need to do is switch the wall switch on and, off a few times while you press the lamp button (off press the button then: on press the button) no go? then: check or, replace the hand remote nine volt battery. still no go? then:
Check the wattage of the replacement bulb; some high wattage bulbs will rob power from the remote unit. didn't work? OK,
next turn off the power to the lamp and, open the lamp cover: you will see a large plastic rectangular box (the reciever) open the cover on the box and, you will see a block of tiny switches then: open the hand remote battery case it too will have a block of tiny switches these must match i.e. 1,3,5,= on 2, 4, = off both the remote and, reciever box. Barring that'll need a new reciever for your fan.
Jun 01, 2010 | Hunter 27187 Remote Control
Unable to get fan to respond to remote Hampton Bay 54
these fans must be reset as follows remove the battery from the remote manually turn off the wall power switch put the batteries back in the remote turn on the wall power switch press the remote buttons...if this doesn't work let me know
Jun 01, 2009 | Universal Remote Control Hampton Bay...
Lights are on all the time, fan doesnt work, remote does not work
I have changed the remotes on 5 Hunter fans in the last 3 months. They have a problem with how some of them mount, that makes them drop down and vibrate loose. If you do not have a wall switch for it, you may want to go to pull chains, or just replace the remote. It is NOT the controller you hold in your hand, but the part in the fan. (never the easy way right?) The remote is not hard to change, but you DO have to let the fan hang from the holder on the ceiling bracket, It gets too heavy to hold while you change the remote.
All but one of the remotes I have changed, came from a mass market type of builder/handyman store, and they have just replaced the part at no charge.
Dec 21, 2008 | Hunter 52" Ceiling Fan With Light And...
I assume that you're talking about a remote-controlled ceiling fan.
There are two parts to a remote-control setup -- the transmitter (the switch which you use to operate the fan and/or light), and the receiver (which receives the signals sent by the transmitter, and directly controls the fan and/or light).
The receiver -- which should look like a plastic rectangle, usually white, grey, or orange-brown in color -- can be identified by the fact that it has several colored wires coming out of it, and doesn't have any buttons. This is mounted in the ceiling fan itself. On nearly all setups, it goes inside the canopy (the decorative part of the ceiling fan, up by the ceiling, which hides the fan's electrical wires).
The transmitter may be either hand-held like a television remote control, or in-wall mounted like a light switch. If you have the hand-held variety, there is nothing to install in a wall box. The wall-box wires should be appropriately connected up, and a blank cover plate should be put on top of the gang box.
If, on the other hand, you have the in-wall variety of transmitter, then yes -- it gets mounted in the wall, in a gang box, like a normal light switch or outlet.
If you need any further clarification, please feel free to ask!
Jun 17, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
23 people viewed this question
Top Dryers Experts
