Question about Shark Vacuums
MY SHARK SC630W PORTABLE STEAM CLEANER WILL NOT MAKE ANY STEAM. BLUE LIGHT IS ON, UNIT HEATS UP, BUT NO STEAM. I HAVE CLEANED THE NOZZLE. ANY SUGGESTIONS?
  • 4 Answers
SOURCE: Euro-Pro Shark hand held steam cleaner model #sc618hd
Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
Posted on Oct 18, 2008
satch498
SOURCE: shark steam mop
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
Posted on Jun 30, 2009
  • 31 Answers
SOURCE: steam cleaner does not get it to steam pressure
scaled up temp sensor, faulty thermostat
Posted on Jan 07, 2010
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
heatman101
  • 43501 Answers
SOURCE: Shark steam mop heats up but stopped putting out steam.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
Posted on Sep 04, 2010
My shark portable steam pocket is not producing steam. What is the problem?
It sounds like the heating element is not working. I can't offer you much more, but I would check that as much as you can.
Jan 10, 2015 | Shark Vacuums
Where can I get a diagram of the inside of a Shark Steam Mop, Model S3901
Unless you\'ve been using distilled water in this unit, it will be collecting a sort of scale layer of calcium, lime, etc, on the interior walls of the steam chamber. When you clean the unit, with a cleaner of your choice, you will get a lot of this stuff off and out when you drain, but frequently there will be a few small chips that will decide to break loose after the main loosening and draining. Sometimes one or more of these errant chips of scale will find it\'s way to the heat channel of the unit and won\'t let the heat out, even though you just cleaned it. If you have or can find, one of the large paper clips, bend one of the tangs out straight and use it to sort of bore out the holes in the bottom, this will sometimes help tremendously. Occasionally, a second dousing of the same treatment is in order, to pick up those last little left over pieces.
Apr 28, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark portable steam cleaner heats up but does not produce steam
Built in thermostat...sounds like you need to buy a new steamer.
Dec 12, 2013 | Vacuums
I need a small tube that runs from the water reservoir to the pump
Go to the hardware store with the old hose. They have several sizes and can cut to length for about a dollar. If you want it to last go to auto parts store and get rubber fuel hose.
May 27, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I need a hose concentrator nozzle for a portable shark steam cleaner.can't find the correct site to order one
Are you talking about the Angle Concentrator/Brush Adapter for the SC505? If so, I have one for sale. Contact me at rbvasanj@yahoo.com and I can send you a pic to see if that is what you need.
Mar 17, 2011 | Euro-Pro Shark SC-505 Handheld Steam...
I have a shark steamer, light is on but no steam. ...
Nope...no cleaning to it...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
May 20, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam won't shut off
I have portable steam sharrk, had same problem. I filled it with water and now works fine, water level might be to low
Jan 07, 2009 | Kenmore Euro-Pro Ultra Steam Shark II Hard...
Vacuums Logo
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
