Question about Singer Sewing Machines
I have a Zigzag singer 277 sewing machine. i do not have an operational manual for it. would anyone help please. Also how do you wind a bobbin on it. thanks
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
textile
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
SOURCE: can't wind bobbin kenmore 16221 sewing machine, no manual
On the right side of the machine there is a large knob at the top. Pull that out and you can wind your bobbin. Don't forget to push it back in so you can sew :)
Posted on May 02, 2009
  • 139 Answers
SOURCE: Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Posted on Apr 16, 2010
I have a Zigzag singer 277 sewing machine. i need to know how wind a bobbin. i do not have an operational manual. please help.
I hope this link might help http://pages.sewing-machine-manuals.com/173/PictPage/3923927771.html
May 15, 2017 | Singer Sewing Machines
Hiya. I have a very old singer, with the number F2590752. Would anyone be able to point me in the right direction to find a manual please? Many thanks.
It's not likely you are going to find a manual for a vintage Singer. However, the older Singers didn't change a lot from one model to the next, so you should be able to find information on multiple web sites and videos that would be helpful.
Singer Sewing Machine Company Serial Numbers
vintage Singer threading Google Search
vintage Singer user manual Google Search
old singer wind bobbin Google Search
Nov 13, 2016 | Sewing Machines
I'm trying to load my bobbin on my singer 628 and the bobbin doesn't wind. Any ideas?
Anon, Found links to help with bobbin does not wind, make sure to read the articles in the forums, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://ca.answers.yahoo.com/question/index?qid=20070630202938AAGRwx2
Singer 628 Touch and Sew sewing machine manual smm043 Machines name begins...
Thread Singer 628 Touch and Sew Questions
Apr 05, 2016 | Singer Sewing Machines
My singer futura will not sew you can only hear the engine but the needle wont go up and down
check for a broken drive belt in the right end of the machine
take it in for a service
Feb 28, 2016 | Singer Sewing Machines
Why does display read "WINDING BOBBIN" and won't clear?
This video may help:
Winding an Elna bobbin
Perhaps the bobbin winding mechanism has not been released. (She unsnaps the bobbin when finished winding.)
Aug 31, 2015 | Elna Quilter's Dream 6003Q
I was doing fine zigzag, ran out of bobbin thread did not change any thing and now the thread bunches on the bottom and the machine does not advance. Bobbin casing pop up also this is a 774 model
Well The most probable cause of the lower thread breaking is an improperly wound bobbin. Regardless of where you wind the bobbin, inside the machine, on the top of the hand wheel or on the front side near the hand wheel, the basic "bobbin" rules apply.
** Always start with an empty bobbin. Never wind one color over another color.
** Don't wind the bobbin so full that it would be tight and hard to insert into the bobbin case. Most machines have an automatic "shut off" when the bobbin gets full, but if yours does not, be careful not to fill it too full.
** Wind the bobbin evenly across and in level layers.
** Never mix different sizes of thread in the bobbin and on the spool, unless you're doing sewing machine embroidery or some specialty type of sewing. Using different weights of thread on the spool and in the bobbin for general sewing will cause ragged stitches as well as other stitching problems.
So clean all the threads and do it work from start.........
Please reply ......
Thanks
Dec 29, 2009 | Singer Sewing Machines
I have a singer model no. 507 (hush matic) but don't have a
Singer sells manuals on their site (a few you can download for free) at http://www.singerco.com/accessories/manuals.html.
Jun 29, 2009 | Singer 5070 Mechanical Sewing Machine
Sewing Machines Logo
22 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
