Question about Vacuums
How do I take the power head off the vacuum wand.?
    Master:
  • 923 Answers
Try using a hack saw. That should do it!
Posted on May 15, 2017
My Ultralux 2000 vacuum power head does not work on my machine but does work on a different machine. What are the possilbe problems? I tried replacing the hose with a new one and that didn't help.
It's probably due to bad wiring connections between the wands, hose and wand, or power nozzle and wand. If it came with the Sidekick, try using it on the end of the hose. If not, simply try using the power nozzle on the end of the hose (no wands). If it works, then the problem is going to be with the cord sections in the wands. Check them good for cracks, breaks, and discoloration at connections. Replace if necessary.
Jan 05, 2011 | Electrolux Eureka Easy Clean 2 in 1 Stick...
I think the power head is clogged with pine needles. The carpet head is not picking up. How do I open it to clean it out?
Make sure you have suction at the end of the hose. If not, the clog is most likely in the hose. Detach hose from vacuum and wand. Drop a coin into one end and allow it to fall through. If it doesn't drop out, the clog is definitely in the hose. Then visually check the wands for a clog
Disassembling the power nozzle is not necessary, or recommended. First, ensure the clog is in the power nozzle. Drop a coin in the wand end and see if it falls out. If not, the clog is elsewhere. You should be able to clear the power nozzle by disconnecting the wand. Use the handle of a table knife to try to push the clog back through the power nozzle, toward the brush. If that doesn't work, try using long nosed pliers to clear the clog.
Jan 04, 2011 | Rainbow 75th Anniversary Canister Vacuum
Power Head keeps cutting in and out while vacuuming???Canister motor keeps running but the power head starts and stops like there is a short or some loss of connection somewhere. Any ideas?
My kenmore progressive vacuum had the same problem. The electrical terminal at the bottom of the wand was corroded. I used a flat head screw driver to scrape the female portion of the connector as best as I could. I then took off the plastic cover on the vacuum head that had the male portion of the connection. I used sand paper to clean the two connection prongs. I also spread them apart slightly for better connection (more interference) when the connection is made. I reassembled, and our vacuum is working fine now. I hope that helps.
Jan 14, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
The beater does not work. the restart button is not burnt or the switch
Remove the hose and reinstall using the alignment arrow at the top of the hose insert. Be sure the hose clicks securely and does not twist or rotate right or left.
Then remove the power head from the wand and eliminate the wand. Plug the head directly onto the hose and plug the cord into the wire socket under the hose.
Flip the switch on the head fully back and forth to see if the head will run without the wand. If it runs put the wand back in place and inspect electrical connections and plug terminals when reinstalling. Post back with what you see and results
Sep 10, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Power head does not activate
have you pushed the rest switch on the top housing? It may be on the side?
Aug 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Same issue...need replacement wand for fantom lightning
I have the power head, wand & hose, exrra belt, 4 heps filters ans a spare main vacuum motor for Fantom Lightning. My main motor burned out. Found a used motor on Ebay. Went to change it and part of wiring was burned, so I decided not to rosk reairs with bad wiring. Power head was not attached at the time, so it is fine. I'll sell all together for a decent price, it you're interested
Aug 09, 2009 | Fantom Vacums Lighting Canister Vacuum
Nedd power head wand for Fantom Model BPSRLC51
the best bet would be to look on ebay. the fantom line was discontinued
Jul 28, 2009 | Fantom Vacums Lighting Canister Vacuum
No spinning in the power head
First, check the red reset button on the power nozzle head. - if it's popped out, push it in. Also, if you have a switch on the handle, make sure you're pressing it while you're vacuuming. if those obvious solutions are already remedied, you may need to check the power outlet on the canister for voltage with a voltmeter while the vacuum is running, and then check your power hose and wand for continuity (checking for a broken wire) while the hose is disconnected from the canister. If all this checks out and the power nozzle still doesn't power on, you may have a bad motor in the power nozzle. If you're good at taking things apart, then it's a simple fix to replace the power nozzle motor.
Jul 03, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Electrolux oxygen vacuum
WARNING WARNING Danger danger Will Robinson! The power head "wand" and the hose from the body of the vacuum have shorts in them. While my wife was using this machine.. she started smelling plastic.. seeing whitish smoke and then sparks... The pin connector arc'd through the plastic... Some research on Google found that this has been a large problem for Electrolux, when i tried to call the factory.. robots.... no solution. Then I contacted a distributor and they informed me that it was not really that big of a problem. Only later to say, that they had replaced ALOT of them. My unit was past its warranty period so I just hardwired it. (now the unit is only two pieces, body and hose w/wand.)
Sep 01, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Losing power to stick/floor vacuum
if you have an extension wand, the replacement will cost about $100.00. there is a way to repair both the pwr-cord on the brush assemble and the wand, but it depends on how much damage there is. also you need to check the contacts where the wand connects with the handle,and the prongs on the handle.
let me know if you still need help
Jan 11, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
