Question about Kubota Garden
Kubota model b7300,hsd.bottem pto locked.but top or rear pto works fine,driveshaft is dis,
4 Suggested Answers
  • 586 Answers
SOURCE: Kubota Shredder not working.
There is a gear inside the motor that allows the blade spin, if it is broken, the motor will spin but the blade will not spin. This is the wheel that connects the motor to the blades.
Between is a single plastic gear which is chewed up the instant resistance is great enough. fabulous
engineering. not a difficult fix.
Therefore, it is the plastic gear within the motor that needs to be replaced.
Hope this was helpful to you.
Goodluck
Elect_Comp
Posted on Jul 04, 2011
  • 331 Answers
SOURCE: change seal for PTO kubota f3680
Remove the PTO shaft extension from the shaft put a drain pan under to catch the oil Tap a chisel or other tapered tool in behind the seal flange and work the seal out install a new seal an re-install oil up to full level
Posted on Jun 13, 2015
rustfarmer
  • 5316 Answers
SOURCE: That's my kubota g4200. The front driveshaft that goes to the mowing deck driveshaft. I got the shaft out. How do I get that casing out. The bearings in the rear are out. Thanks
Slide hammer? BTW this is posted in the wrong section.
Posted on May 09, 2016
Kubota zd28 mower was running fine put away but now PTO wont engage.
if your saying that pto wont do anything , that's either an electrical short or a broken belt , in rare cases the clutches go too , now if your saying the pto engauges and stalls the engine or makes horrible noises , then that's a bearing , im betting the deck shaft bearings are in need of some serious grease work
Mar 04, 2017 | Kubota Garden
PTO lever engages in the wrong position in a Kubota ZD323.
Check and make sure that any links are not bent and make sure that the switch that engages the PTO is not out of adjustment.
Jul 14, 2016 | Kubota Garden
3 point hitch won't go up wuz working. On a kubota tractor
is the pto lock on if not checkto see if hydraulic fluid is at normal operating level:) i had this problem a while ago!!!
Aug 17, 2015 | Kubota Garden
Kubota F3680 stalls when PTO is engaged
there is not enof power so olter the tick over
Jun 28, 2015 | Kubota Garden
Change seal for PTO kubota f3680
Jun 13, 2015 | Kubota Garden
Kubota L 3300 rear PTO will not engage when very cold weather solution please
Try using a lighter gear oil - some oils are thicker in really cold temps - like molasses while its warm drain it and use a lighter grade, - check the manual and go with a thinner type - ask local car parts store. sometimes the manual will give a type for colder weather. Good luck
Nov 30, 2014 | Kubota Garden
Pto onmy kubota zero trun zg 23 wont work
Check to make sure you are getting power on both sides of the switch. Check the connectors going to electromagnetic engagement PTO unit. This is mounted right on the base of engine. Check ground wire coming from unit to make sure you have agod grounfd connection.
Feb 27, 2014 | Kubota Garden
Garden Logo
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
