Question about Garden
Mower won't start after i installed a new blade belt
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
wadembly
  • 513 Answers
SOURCE: problem replacing belt on a ols rear engine snapper?
what kind of mower & model # i may be able to help thanks wade
Posted on Jul 04, 2009
brado83
  • 106 Answers
SOURCE: need diagram for installing mower belt for blades
Hey if its a 42" cutter deck this should be the one:
http://i876.photobucket.com/albums/ab330/Brado83/JDDeck.jpg
It may be a 48" in that case it would be different
Brad:)
Posted on Sep 16, 2009
braintrust
  • 62 Answers
SOURCE: after replacing the belt, new pulleys, and bolts,
sounds like the linkage to your blades, check your lever, to make sure its working right may need some grease, it may be sticking and not fully engaging, or doing its job when its supposed to
Posted on Oct 27, 2009
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
Lawnmower wheels won't drive
If its a riding mower it probably the drive belts off track or slung off. The mower will still start up and turn blades with the drive belt off, but want engage to go forward or reverse if this is the problem.
Aug 17, 2013 | Garden
Why does my Cub cadet mower blade stops and not restart?
check for worn belt or tensioner not being tight enough. check for a failed bearing on a cutter spindle.
Jun 16, 2013 | Garden
My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
Apr 12, 2012 | John Deere Garden
I engage the mower blades, put the tractor in drive and the blades stop
sounds like the safety switch is out of adjustment
Apr 06, 2012 | Garden
I have white zero turn 54" lawn mower. The engine runs but the blades won't turn on. Please any advise will help
This is a belt adjustment problem. You machines belt has either broken, or is loose to the point where it won't engage the blades at all, or has just slipped off the pulley. I believe the belts are on top of the deck covered by removable covers that are bolted to the deck. Check and see. GOOD LUCK.
Jun 17, 2011 | Hawk 36" Red Hydro Walk Behind Lawn Mower...
Problem with John Deere L120 tractor
Jul 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
REPLACING A RIDING MOWER BELT BLADE
Hello. REmove the deck from your mower so you can easily get at the belt and the blade. Make a drawing of how the belt is installed so you can install the new one the same way, loosen the idler pulley and remove the belt. Generally you have to remove a couple of parts to get the old belt off in one piece and get the new one on. You will need a set of socket wrences. To replace the blade use a block of wood to hold the old blade stationary and a large socket wrench to loosen the nut holding the blade in place.
Nov 25, 2009 | Garden
How to change the v-belt on a craftsman walkbehind lawn mower,
Remove the belt cover, Remove the blade and blade adaptor. Remove belt guard and slip off old belt. Install new belt just like it was removed. Install parts and you should be good to go. Hope this helps
Nov 20, 2009 | Craftsman Garden
Problem replacing belt on a ols rear engine snapper?
Jun 22, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
