Question about Hayward Pool & Spa
What type of sand and how much for my Hayward GM 245 sand filter ?
    Top Expert:
  • Hayward Master
  • 7,905 Answers
Silica sand and look on label of filter for amount
Posted on Sep 05, 2017
2 Suggested Answers
StepehnD
  • 78 Answers
SOURCE: Does the Hayward GM-245 Sand filter tank separate
I am not that familiar with the G series Hayward filters, but most sand filter tanks do not separate. It's a labor intensive job so think hard before trying it if you haven't before. If your backwash valve is on top of the filter, the plumbing will have to be removed. There are two ways that I have removed the sand. Scooping it out by hand or using a shop vac. Remember the sand is going to be very heavy when wet. You will need to go through the top. Some filters have a large drain plug in the bottom that "supposedly" you can drain the sand out through.I have done this once and it makes a big mess that you still need to clean up.
Be sure to buy replacement o-rings and gaskets as needed. There is also a product called a sand vac that is in essence a siphoning system.
Be careful not to damage the laterals it the bottom of the filter. When replacing the sand, I put small gravel (pea gravel) carefully under and partially around the laterals to help support them from the weight of the new sand.
When you are done, be sure to backwash the new sand to remove dirt, impurities, etc. This is a general overview. There are books online that give more detail or use a similar filter's manual...
Posted on Jul 27, 2010
What type of sand do I need and how much for my Hayward GM-245
silica sand and read label on filter for quantity
May 15, 2017 | Hayward Pool & Spa
How much sand do you add to a Hayward Sand filter S-21OT
200 pounds of sand make sure you use pool filter sand make sure not to get sand in pipe
Jun 27, 2014 | Hayward SAND FILTER, PRO SERIES
I put my Hayward ST180T on rinse to vacuum the pool and I ended up with sand in the pool what happen?
You are using the wrong setting to vacuum. This type of pool filter should be set to "filter" for normal vacuuming or to "waste" for heavy loads. The "rinse" setting makes sure that all of the dirty water is out of your filter after backwashing.
Jul 14, 2011 | Hayward SAND FILTER, PRO SERIES
I have a Hayward 160T high rate sand filter. How often should the sand be changed? Can you over shock a pool when you first open it? What type of sand and where can I get it?.
Q. I have a Hayward 160T high rate sand filter. How often should the sand be changed? Every 3 - 5 years.
Q. Can you over shock a pool when you first open it? Only in the sense that a liner or some of the equipment will not like ultra-high chlorine levels and depending on the shock used you can mess up pH and Alkalinity...generally you shock with one pound per 10K gallons.
Q. What type of sand and where can I get it? #20 silica sand...some places will call it fine sand. Do not use the coarse or medium coarse sand.
John
May 29, 2011 | Hayward Pool & Spa
Jul 26, 2010 | Hayward SAND FILTER, PRO SERIES
I have a leak in my above ground sand filter, model 140. the leak is around the drain. How can I fix it? It is a Hayward, high rate sand filter, GM series, model 140ab. Thank you
Usually in th bottom of the filter you have two parts. The first is a piece with a screen that threads into the plastic housing. The second is a Cap with a rubber washer inside. Make sure the rubber washer is there. Do not overtighten the drain into the houseing
Jul 24, 2010 | Hayward Pro Series 18" Above Ground Pool...
Can you backwash on a Hayward swim pro filter system
Yes you can. The only filters that need disasembly are cartridge filters. Here is the link for the Hayward owners manuals. The manual explains the procedure depending if you have a multi-port (rotary) or push/pull type valve.
Jul 16, 2010 | Hayward SAND FILTER, PRO SERIES
Sand in above ground pool
what type of sand make sure its for pools should only have 2 bags max in filter
Jul 24, 2009 | Hayward Pro Series 18" Above Ground Pool...
Hayward sand filter pressure builds up and return hose pops , the flow is good.
pressure should be at around 10 if its higher backwash to bring pressure down make sure you are seating hos clamp screw type over ring on return pipe
Jun 22, 2009 | Hayward SAND FILTER, PRO SERIES
Replaced sand now filter isnt working
if u used play sand, or any other type of sand thats NOT pool filter sand, that could be the problem. also if there is too much sand or too little sand that could also cause this.
Jun 08, 2009 | Hayward Pro Series 18" Above Ground Pool...
Pool & Spa Logo
106 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
