Question about Samsung Televison & Video
My tv's standby light blinks once when i turn it on and I never get any display. It seems to try and come on, but power off again.
Samsung TV, model un55h6350afxza, version th01, s/n 022c3caf30
  • 3 more comments
  •  Russ Hill
    Russ Hill May 15, 2017
    Have you a voltage meter to check the volts from the board to the av board. the voltages need to be correct.
  • Charles McBride
    Charles McBride May 15, 2017
    I can check, is there a good source that would have the pinout and expected voltages? Thanks for the help guys!
  •  Russ Hill
    smasung are usually good at putting the voltages out on the board so look there. they have different power board for the same model so you would need the board number to check the voltages but like i say they usually have it written on the board
  • Charles McBride
    Thanks for the info! After I found the voltage printed on the board and tested, the voltages were slightly off (20%) and I could hear a buzz from that board when I tried to power it on. Part ordered.
  •  Russ Hill
    Russ Hill May 21, 2017
    nice one at least it should be up and working when new board is fitted
  • Samsung Master
  • 3,980 Answers
It could be a week power board, check the capacitors on the power board and that look like they have a rounded top will need replacing, this is a common fault, over time they just wear out for use, replace with same rating on the capacitors, make sure they are 105c type.
Posted on May 15, 2017
Testimonial: "Okay, I did look and there aren't any signs of a blown capacitor or burnt component on any board. I wasn't sure if the fact that the standby light was on pointed to the main board. Thanks"
  • Charles McBride
    Charles McBride May 19, 2017
    You nailed it. Power board was producing 11v instead of 13v. Replaced the part and it's as good as new. Thanks again!
Looking for E-Manual to download for samsung tv Model UA32V6000VFXXY VERSION BN01
Try Googling (Samsung)(UA32V6000VFXXY)(manual) without parens. You may have to refine your search to find version BN01.
Apr 25, 2018 | Samsung Televison & Video
Tip
How to find out the series number and model code of a Samsung Smart TV
1. From your Smart Remote press the Menu button
2. In the menu displayed in the TV , select the support option
3. Select Contact Samsung option in the Menu
This displays the Model number / code, firmware version and other details of the TV. Scroll down the popup menu to view other details of your TV.
on Jan 09, 2015 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Samsungtv,when turn on red light blinks 6 times.no display, no sound. Replaced power,main and tcon boards,all seems to be ok.have also checked led lights all of them fine. what could be the problem?
Almost sounds like you received a defective replacement board, check the various voltages coming from the PS board and see if they are ok, if they are then the PS is working and you can eliminate that board
Oct 27, 2017 | Televison & Video
My samsung led tv, when i turn on red light blinks 6 times. no display, no sound. Tried replacing power board, main board and tcon board, all of them seems to be fine. What else could be the problem.
You have at least one bad LED in the panel and its shutting down the power supply...for future reference a bad Tcon will not cause loss of sound only affects picture
Oct 26, 2017 | Samsung Televison & Video
TV has sound but there is not a picture. Model code: UN32EH5300FXZA Version No. UU02 Ac110-120v ~60hz 69W Typical power: 29W
Hi Ben,
Back light failure is a common problem with these sets. If it is so, I am afraid you can not repair it by yourself. You will need a qualified and experienced technician to handle it.
Jul 12, 2017 | Samsung Televison & Video
Is Samsung model # UN55D6050TF a smart TV? Model Code:UN55D6050TFXZA Version No: H301 S/N: Z3333CAB801334D Is it a smart TV with Apps already on it?
You have to connect the TV to internet first & access the smart function, then the Samsung internet Apps will be updated.
Apr 26, 2017 | Samsung Televison & Video
Dark shadows on LED TV
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 28, 2016 | Samsung Televison & Video
I took my samsung 50" DLP TV model # HLR5067W to a repair shop and they said my digital board is bad. I also called Samsung and my warranty was up and they said I was basically SOL. Where can I get a...
First thing is look at the model number of the TV and make sure of the complete model number. For instance there are 2 versions of this model requiring 2 digital board numbers. If your model is just HLR5067W the part number is BP94-1858A if the model is HLR5067WAX the part number is BP94-02084A. I bet yours will be the later of the 2 since that is a high failure version. They are NOT cross compatible. The parts you can purchase from Samsung at http://www.samsungparts.com
Please take a moment to rate my answer...Thanks
May 18, 2010 | Televison & Video
Televison & Video Logo
99 people viewed this question
Jerry Greenberg
Jerry Greenberg
