Question about IFB Washing Machines
My washing machine IFB showing error is E1. HOW TO SOLVE. PLEASE CLAIRIFY
  • 641 Answers
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Posted on Aug 16, 2007
SOURCE: Can't get rid of E1 error on a Samsung front loader washing mach.
E1 : washing machine has exceeded a check time for fill, heat or empty.
Common causes for this are fill and empty problems, heater fault (or the wiring
to it broken), water pump open circuit (although that would stop the water draining too) Pressure chamber blocked or pressure tubing pipe looped below the pressure bottle, or a sticking eco ball in the sump hose (sludge and grease build up)
This error code is generic and vey common.Since you have tried the remedies.Try getting checked the internal wiring damage by professionals.I hope certainly hope the problem lies there.
Posted on Dec 10, 2008
  • 423 Answers
SOURCE: What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Posted on Mar 30, 2009
  • 1738 Answers
SOURCE: error e1. washing machine will not drain
Two problems. Step one check the drain pump motor, to see if it draining the water out. Next step if the drain pump working you have a clock in the hose between the drain from the tub to the pump. Messy job witht he machine being full of water. I suggest take a small bucket and empty try to empty it out as much as you can.
Posted on Aug 10, 2009
SOURCE: hi am getting e1 error in my washing machine
what is an E1 error message
Posted on Jan 04, 2010
My ifb front load washing machine is showing door error, how can i rectify it
the door is not closing properly so not making the door switch contact to tell the controller to go to the next cycle replace the door lock problem solved eric
Dec 22, 2017 | IFB Washing Machines
IFB washing machine showing dl er...what can I do ?
Mar 20, 2017 | IFB Washing Machines
Ifb washing machine showing DOOR NOT CLOSED
Visit the sites linked here for more details about the error cddes to many brand washing machine, and dish washers.
http://electrotechnician.blogspot.com/
https://electronicshelponline.blogspot.com/
http://homenol.blogspot.com/
Aug 10, 2016 | IFB Washing Machines
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
My ifb washing machine is showing dp error
Jul 05, 2014 | Washing Machines
IFB washing machine front load Showing ' Lo' what
Error code LO normally means the filter is blocked. this would be the best place to start. refer to your owners manual for instructions on cleaning this.
Aug 10, 2013 | IFB Washing Machines
Why ifb machine displaying P11 and P10?
Could you please describe the problem you are having a little better?
Nov 27, 2012 | IFB Washing Machines
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
Washing Machines Logo
32 people viewed this question
Top IFB Washing Machines Experts
Eric Taylor
Eric Sutherland
Ken Strite
Ken Strite
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
