Question about Wurlitzer Audio Players & Recorders
Wurlitzer 3700 jukebox selects record and plays but DOES NOT RAISE ARM TO SELECT NEXT SONG at end of playing record on turntable. If I push it manually it will respond. How can I reset the arm
    Master:
  • Wurlitzer Master
  • 923 Answers
Why don't you acquire a time machine, and go back to when Wurlitzer was building those, and ask them what to do?
Posted on May 15, 2017
Can't play discs
i can send you the manual to fix it
Sep 18, 2012 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 jukebox
It is the arm sensor for the end of the disk.
Apr 05, 2008 | Wurlitzer Jukebox 1015 One More Time...
I have a Wurlitzer one more time. vinyl record jukebox.. I moved ( or turned) the turn arm forward to clean behind it and now the records will start to play and return to the changer. How do I adjust it.
Look up underneath the mechanism. You've moved the tone arm with respect to the bracket beneath it (which closes the trip switch). Select a record...turn the machine off...then look up under whilst someone moves the tone arm and you will see what it is attched to. If you are lucky you can hold that tight and gently move the arm back the other way a bit.
Jul 28, 2011 | Wurlitzer Jukebox 1015 One More Time...
45 (record) Jukebox. While playing the jukebox was changing records, the arm lifted the record slightly off the turntable. the credits and song selection would not clear off the readout, even after...
Have you checked all the fuses or circuit breakers on the jukebox?
Are all the power supply led's lit?
Make sure that all the connection plugs into the boards are fully seated and making good connections.
After checking the above if the fault remains you will need to contact a Wurlitzer service engineer.
Regards
Alan Hood
ami-man
UK
May 23, 2011 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600 series wont select a record ?
If the buttons don't latch in, the machine is not in credit. Put on free play or put some money in.
Dave F.
May 30, 2009 | Wurlitzer Jukebox 1015 One More Time...
2900 Keeps playing records
THE WURLITZER JUKEBOX WILL CONTINUE TO PLAY SONGS AS LONG AS ONE OR MORE, SELECTING PINS (THERE ARE 200 IN THE 2900 ONE FOR EACH SONG. THE PINS ARE IN LOWER SECTION OF THE CASE. BETWEEN THE SPEAKERS , AND LOWER DOOR.)
REMOVE LOWER BACK DOOR. WATCH THE ARM THAT STOPS ON THE NEXT RECORD, BECAUSE THE PIN IS UP. AFTER STOPPING ON THE PIN, THE ARM PUSHES THE PIN DOWN. THAT IS THE NORMAL OPERATION. IF THE PIN, IS NOT PUSHED DOWN, IT WILL PLAY THAT OR ANY OTHER SONG THAT HAS A PIN IS RAISED UP. THE PINS ARE THE MECHANICAL MEMORY FOR THAT JUKEBOX.
TURN OFF POWER, ==PUSH ALL PINS DOWN== THE SONGS WILL STOP PLAYING. THEN MAKE A SONG SELECTION. THE ONE PIN WILL POP UP THE MACHINE SHOULD PLAY THAT SONG.
WATCH THE ARM THAT STOPPED TO PLAY THE SONG, PUSH THE PIN DOWN. THAT IS THE SEQUENCE OF THE 2900 MACHINE,
WHAT CAN GO WRONG IS AS FOLLOWS. ==THE ARM DOES NOT PUSH PIN DOWN== THE ARM MISSES PIN== THE ARM NEED OIL, IT IS NOT LUBRICATED.==.
Mar 08, 2009 | Wurlitzer Jukebox CD Player
Seeburg Stereo Phonograph Model ESL100 Q-65-H5
End of record switch out of adjustment or bad? Disconnected?
Mar 05, 2009 | Wurlitzer Jukebox 1015 One More Time...
NSM Hit120 Jukebox.
there is an opto sensor the gets blocked when the tone arm is at the end of the song. It looks like a black u mounted on a circuit board. The flag that interupts the sensor is on the tone arm. The opto must be dirty so it thinks it's at the end of the song and continues to the unload sequence dispite the tone arm having just started playing.
Jan 03, 2009 | Audio Players & Recorders
No sound on 2710 Wurlitzer
Find the input to the amp from the tone arm. Play a record and while it is playing unplug the tone arm input. Stick a paperclip in the input of the amp...if it doesn't go HUMMMMMMMMM.....you have a dead amp....or the speakers arent plugged in.
Dave F.
Dec 08, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1800 jukebox, plays record but at end the arm does not lift so record does not reject until I press the reset button and then it works.
If the normal cancel button is working then take a look at the tone arm trip switch, which probably just needs adjusting. You can test this by flicking it with your finger when a record is playing. If it works it just needs adjusting to trip at the right place on the record.
The trip switch is located behind the fat end of the cobra tone arm on the back side of the arch, so you get to it by taking the machine back door off.
Dave F.
Nov 29, 2008 | Wurlitzer Jukebox 1015 One More Time...
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
