Question about Ovens
Need glass cover for oven bulb - Ovens
  • Ovens Master
  • 2,990 Answers
Hello Ronald Reynolds,
Those are going to vary by the make & model...
If I knew... for example, that your OVEN
was a USA manufactured unit I could
refer you to a number of parts houses
(they all peddle the same quality (opinion)).
Like (for example)
appliancepartspros
Search Over 2 1 Million Appliance Parts
partselect.com
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Or you could (Disclosing your MAKE & MODEL) search on the internet for "PARTS" in the USA... "SPARES" for the UK & rest of the world...
Even AMAZON ...
and eBay for the really obscure/exotic parts...
Hope this helps... Happy hunting!
Posted on May 15, 2017
  • 1,830 Answers
What type of oven is it? How old is it? Model#
Suggest asking for help at Home Depot first.
How do I replace a blown buld in the main oven
In most ovens, move the metal bracket to one side. the glass dome cover should fall out. Unscrew the old bulb. Screw in the new bulb. Place the glass dome cover back over the bulb. Move the metal bracket to hold on the glass dome cover. Easy job to do.
Aug 23, 2015 | Stoves Premier 720EMa Electric Double Oven
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
How i can change the lamp in my Bosch oven?
Remove the glass cover and unscrew the bulb.
Dec 04, 2014 | Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
Replace bulb
oven bulbs are special bulbs only available from an oven service agent
although the ratings are the same , the glass used is actually pyrex glass as ordinary glass will not handle the oven temperatures
Dec 24, 2017 | Viking Professional VESO130 Dual Single...
How do I change the bulb in an Inglis oven. Can't
Normally the cover will have an anticlockwise turn thread. Twist the glass cover anti clockwise and it should unscrew.
Jan 04, 2010 | Ovens
How to replace oven light bulb for beko DC543 electric cooker
hi
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    http://www.espares.co.uk/advice/cookers-and-hobs/a/1/112/changing-your-oven-light-bulb.html
    hope u will b helpfull
    tnx for contactin fixya
    regards
    Jul 12, 2009 | Ovens
    Trying to replace main oven bulb: cover jammed
    Try heating it up with a hair dryer or similar if that does not work then you will probably have to break the glass cover.
    Nov 17, 2008 | Neff U1461 Double circotherm plus Electric...
    Oven bulb
    i have a ge profile double oven and the glass cover on the top convection oven is held in place by grooves that latch onto the glass dome cover. Just turn the dome so that the handles on the glass dome cover are exposed. I used a flashlight and a screwdriver to push the dome to one side.
    Dec 25, 2007 | GE Profile JTP56 Electric Double Oven
    Oven
    Pry back the bulb glass cover wire spring and remove glass cover. Use heavy rubber gloves or a plastic bottle opener(piece of serrated soft plastic/rubber) and unscrew counterclockwise.
    Mar 05, 2007 | Whirlpool GBS277PR Electric Single Oven
    Ovens Logo
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
