Question about Garden
Where can I get a quick release black hose connector for a Parkside PHD 150 E4 pressure washer. Mine has snapped
    Habit-Forming:
    New Friend:
  • 12 Answers
Water hose won't come off pressure washer
release pressure by squeezing trigger then grab the brass quick connect fitting at the knurled section (at end of hose) and push it toward the pump. when properly pushed back, the hose connector will pop out.
Aug 11, 2014 | Craftsman 2700 PSI Briggs Stratton...
How do I release pressure from the hose on a pressure washer
would it be possible to unscrew the quick connect fitting SLOWLY until water starts to drip out of threads thus allowing the pressure to drop down slowly to the point of being able to release the hose coupler?
Jul 28, 2014 | Dewalt Pressure Washer. 4200 PSI 4.0 GPM...
Install replacement high pressure hose
If you are replacing the hose because it burst you might contact the manufacturer. Mine, of a different brand, burst and they sent me a new pressure washer saying that it was very difficult to install a new hose. They had a lot of problems with hoses from China.
Apr 09, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
I bought a Parkside pressure cleaner,but I have no idea how has to be connecting?Becouse I can't connect by top water.Probably has to be connecting where is washing machine?Help me.Thank you.
You need a garden hose and outdoor spigot although it is possible to connect where the washer connects but is a real pain. You can also get an adapter to connect a garden hose to your "Tap Water" faucet but it is not recommended as you will likely break the faucet off.
Mar 12, 2011 | Garden
Leaking at point of connection between tip and wand
There is a rubber o ring in a groove towards bottom of the snap in connector.This seals around the tip as you insert it. It will never seal without it. The ball bearings you mention are only to hold the tip in place. The sealing goes on down in the coupler
Jul 02, 2010 | Briggs & Stratton Briggs Stratton ORing...
I can use my Karcher K3 jet wash as long as i hold trigger down
Most pressure washers have ball lock type fittings on the hose connections. What happens is the little steel balls get a bit of corrosion and do not lock the male fitting properly with the female coupling. Load up the fitting with some Oil or WD 40. Then connect and disconnect the fitting several times to losen up the balls and springs. Should the spring in the coupling break you will get the exact symptom your describing.
If the OIL / WD 40 does not do the trick then you may have to change out the quick disconnect coupling.
Kelly
Apr 18, 2010 | Karcher PSI Electric Pressure Washer
How do I change the water level pressure switch on a Kenmore topload washer?
I believe you can remove the screws on top control unit should be 1 on each side then flip back control unit ,remove the hose ,connectors,pressure swith, i had a problem with mine and found out that the hose had fallen off quick fix!
Jan 09, 2010 | Kenmore 24032\24036 Top Load Washer
Popping while removing Hose Adapter
Are you sure the adapters are installed in the correct direction? To release the pressure you could turn the water off, and then turn the washer on. The residual pressure will be released. Then you can turn the washer off and remove the hoses.
May 06, 2009 | Haier HLP21E Top Load Washer
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
