Question about Tower Dryers
Tower Fan Model FS3-29TF - only hums when I turn it on. Replacement parts?
    Master:
  • 923 Answers
I can tell you why it only hums. It's because it does not know the words to the song!
Posted on May 15, 2017
How do I remove back panel from fridge? It is making a loud noise
The noise is most likely your fan which on most frigs is on the bottom.
There should be a smaller panel made of heavy duty cardboard with a bunch of screws, remove it and look for a small fan about the same size and a PC tower fan, turn the thermostat all the way up to set it off and listen for the noise.
The maker of your frig should have a replacement fan.
If not type in your model and serial number on the internet and someplace should carry a replacement.
Ebay is also a good place to search for the part you need.
Apr 04, 2016 | Refrigerators
All the leds turn on, incluiding the tower fan oscillate, But the essential doesn't work "it doesn't ventilate". What do you suggest?
check the fan if it is working.. if not ,can you hear any humming sound coming from the motor? if there is you need to remove the cover, then remove the circular fan,try to turn on the unit without a fan if the motor is running then just clean the rust in the bushing and shaft of fan by using sand paper. then put lubricant in the shaft and bushing(oil or wd40 or grease). make sure that you remember all the parts and the position of it.. good luck
Sep 13, 2010 | Windchaser WCUFLTI Tower Fan
Azza Orion front fan problem
Put some oil in the fan motor or check if any wires may hitting in the fan while running
Jun 15, 2010 | Azza Orion 201 black/silver SECC Steel ATX...
Fan making humming noise and wont turn
The fan motor cannot turn because either the bearings are dry and turning hard or the motor has worn out...You can try to take it apart and lub the bearing with WD-40 and a light oil... it may work.
heatman101
Apr 19, 2010 | Tower Aloha Breeze Fan
Need a replacement remote for tower fan
CALL 1-800-295-4448 THE WILL SEND YOU A REPLACEMENT
GOOD LUCK
Jul 03, 2009 | Tower Aloha Breeze Fan
Makes a loud noise when it is turned on. Can't open it.
If it is making a loud humming sound it is probably getting weak and will have to be replaced. Is it doing it in all speeds? Motor replacement would probably not be worthwhile unless it is a very expensive unit. I'd opt to replace the unit.
May 16, 2009 | Bionaire BT45RC Tower Fan
Humming noise
The light enigine shouldn't be that difficult to replace if you have a decent amount of time and are moderately mechanically inclined. You can order the original Toshiba replacement light engine for this model (62HM95) from a major Toshiba parts distributor at the link below:
Toshiba 62HM95 Replacement Part Light Engine / Optical Block
Apr 01, 2009 | Toshiba 62HM95 62" HDTV
Aloha breeze fan tower replacement parts
Consumer Contact: For additional information, contact Aloha Housewares at (800) 295-4448 between 9 a.m. and 4 p.m. CT Monday through Friday, or email the firm at ahitexaslg@aol.com
Jan 03, 2009 | Aloha Housewares Breeze 29" Tower Fan
Tower computer
that could only be your cooling fan. initial speed at maximum then turns to lower speeds when system has done POST.
Apr 11, 2008 | Computers & Internet
Dryers Logo
29 people viewed this question
Top Tower Dryers Experts
Jay Finke
Jay Finke
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Tower Dryer Expert? Answer questions, earn points and help others
