Question about Vacuums
How can I get the wiring diagram of steam cleaner xvt1000
Where can I purchase a safety filler cap?
See Google.
[PDF]steam cleaner - Pdfstream.manualsonline.com
pdfstream.manualsonline.com/.../e7f63cef-798e-41f3-bec7-5e43d5da5d...
When using your Steam Cleaner basic safety precautions should always be ... not screw the safety/filler cap onto the .... When using the Ultra Steam Shark II with.
Sep 29, 2015 | Shark Ultra Steam-blaster Hard Surface...
Where can I get a diagram of the inside of a Shark Steam Mop, Model S3901
Unless you\'ve been using distilled water in this unit, it will be collecting a sort of scale layer of calcium, lime, etc, on the interior walls of the steam chamber. When you clean the unit, with a cleaner of your choice, you will get a lot of this stuff off and out when you drain, but frequently there will be a few small chips that will decide to break loose after the main loosening and draining. Sometimes one or more of these errant chips of scale will find it\'s way to the heat channel of the unit and won\'t let the heat out, even though you just cleaned it. If you have or can find, one of the large paper clips, bend one of the tangs out straight and use it to sort of bore out the holes in the bottom, this will sometimes help tremendously. Occasionally, a second dousing of the same treatment is in order, to pick up those last little left over pieces.
Apr 28, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euroflex ez2 stop working
Minerals in the water clog up the steam outlet tube on these units. You have to open the unit and look for the outlet from the steam generator and try to unclog with a wire.
...Ummm is there water in the unit (just asking) :)
Nov 21, 2013 | Euroflex Monster Ez2 Steam Cleaner
A lawn mower black hawk
I have got a little yell o steam cleaner it is getting up to pressure but there is no steam coming out of the nozzle how am I able to fix this can some one help me with this matter please
Jun 14, 2013 | Vacuums
Our SteamVac will not release cleaner and water. Everything else appears to be okay. After last use it was rinsed out and left for two weeks at which time it would not work. I would like to obtain a...
click this link directly
http://www.sacreativeservices.com/forum_stuff/steam_vac/
4931375.jpg af5d9a3.jpg The disassembly procedure with photos for this portion of the steam vac is shown in the first image below. This should help you tear down the unit to a point where you can determine the cause of your problem. The wiring diagram is provided in the second image. You may need this diagram to check the wiring if the motor for the brushes is not running. You can view a parts diagram and order parts for the steam vac on the Sears PartsDirect website.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 31, 2009 | Vacuums
Schematic parts diagram for bissell proheat 9200 carpet cleaner
Hi, just go to amazon here: Amazon com bissell proheat carpet cleaner parts and you can find every needed parts. I hope this was helpful. Cheers
Jul 24, 2008 | Bissell 9200 Upright Vacuum
Euro-Pro Shark hand held steam cleaner model #sc618hd
Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
May 26, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
