Question about Golf
EZGO golf cart just stopped. batteries are fully charged. get voltage at keyed on off switch
  • 923 Answers
What is "supposed" to make it go? A pedal on the floor, or a hand operated control? You probably have a bad switch, or dirty or corroded connections, or broken wire somewhere, or maybe a relay with those problems!
Posted on May 15, 2017
Battery check with voltage meter on ezgo golf carts
Not sure if you're asking a question or just making a statement, however a voltage check alone will not indicate overall battery condition or health.
You need to have a load test performed on the individual batteries in order to determine overall charging system health.
Try this resource: How to Check Golf Cart for Bad Batteries
Get yourself a load tester similar to this:
Amazon com Schumacher BT 100 100 amp Battery Load Tester Automotive
Feb 01, 2018 | Golf
I have a 2010 yamaha golf cart,has brand new batteries,and the batteries drain by nine holes,is it the voltage regulator? or something else
Make sure the batteries are fully charged. if your cart has it's own charger it may not fully charge. I would purchase a portable one and make sure they fully charge then you would know whether the cart charger is working.
Nov 05, 2017 | Golf
I have a 2005 ezgo electric golf cart, I caused a power surge now cart won't run? What did I blow?
This could be really bad. Start by checking total voltage from battery pack. Next check voltage at small posts of solenoid when pressing pedal. No voltage? start tracing the wiring. Voltage yes? then test solenoid. If good then controller might be bad.
May 23, 2017 | Golf
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
Jan 24, 2016 | Golf
36 volt ezgo
First of all, lift rear axle off the ground and place blocks or jack stands underneath. Check to see if you have 36 volts On your batteries. Now you want to run a jumper across the big cables on the solenoid. Press the accelerator and the motor should engage. Clicking is a pretty sure sign that the solenoid is bad. Please let me know if this is useful. I can further elaborate more troubleshooting if this doesn't solve your problem.
Aug 06, 2014 | Performance Plus Carts EZGO Golf Cart 36...
EZGO golf cart won't go forward
Your batteries have died. The reason it will barely move in reverse is that current is being supplied to the motor is a direction that it spends very little time using. There is a slight change in the armature over time, and reverse tends to work better over time. Check the voltage when under load. (run jumper wires from the + and - of the battery bank. If it is a 36 volt cart and the voltage drops to below 36 volts, you do not have enoug current to run the cart. Plug in the charger and watch the ampmeter. If it goes up to about 20 amps, then it is charging. It should take a good charge after 10 hours. If the cart charges and only runs a short distance, the batteries need replacing.
Apr 09, 2010 | 1993 Acura Vigor
Batteries run out of power too quick, what is my problem? ezgo golf cart electric. What would the total voltage be with 6 batteries?
The voltage should be above 37 volts if you have 6 volt batteries. This must be measured under load. A simple voltage check is useless. If the batteries are over 6 years old, they are probably in need of replacement.
Sep 27, 2009 | Garmin Golf Walking Cart Mount For ...
Golf Logo
Top Golf Experts
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
