Question about The Audio Players & Recorders
The drive belt on my record player has broken can I get a new one?
    Master:
  • The Master
  • 923 Answers
Yes, and you don't even have to say what the make and model is. Why? Because ALL BELTS are identical, on every device throughout the earth, so you should be able to get one ANYWHERE! So, just go to an Autozone, or an O'Reilly Auto Parts store, and ask for ANY belt, and it should fit, no matter what it was built for! You could ask for a fan belt, a serpentine belt, or a timing belt, and, since EVERY BELT is always identical ... it should fit, no matter what you get!
This answer should serve to demonstrate how FUTILE it is, to ask a question about a piece of equipment WITHOUT revealing the brand name and model number for the equipment for which specific PARTS are needed!
Posted on May 15, 2017
What can I do when the turntable is not turning?
You most likely have loos or broken drive belt. Look underneath the uni. you'll see if the belt is there or not.
Aug 10, 2014 | ION Audio Vinyl Recording Turntable
Tip
Tips on how to fix the DVD player ( not eject )
You have to check the try loading belt of you DVD. if the belt is loose or broken the will not be ejected. you can see only OPEN in the display. You can simply check is it related to belt. Power on the DVD player and then press the eject button. Place you ear on the top of the player and listen is there is any humming sound (sound of motor running). If you hear the sound then the belt have some problem.if there is no sound then the problem is related to the electronic part which drives the motor. if so you have to change the motherboard of you DVD player. Because the all the parts in it are S.M.D( surface *****device) also the availability of the part is very rare.
If you here the sound then you Can rectify the problem by replacing the belt.Normally you cant see the belt from the top of the mechanism. Because it is beneath the tray. you can see it only if the tray is in eject position.
Remove the top cover of your DVD player. As it is DVD player you can eject the tray manually. for that watch the bottom of your DVD player. You can see a slot closed by a plastic strip just bottom of the mechanism. Pull out the plastic strip. Watch through the slot. you can see a Noach which you can move manually to the left and right. put a screwdriver in it and pull the Noach to the side. the try will get ejected. Not fully but partially. You have to pullout the tray fully manually.
If you closely look at the inner end side of the try then you can see a motor and belt. if the belt is loose it will be in there in the motor pulley and in the wheel. if its broken broken then you have to find it where it . Take the belt as sample and bring a new one. you will get the belt at any of the electronic spare parts shop near you. Put the new belt in the position. insert the tray by pushing it in to inside slowly. power on the DVD player and the press the eject button.
on May 02, 2011 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
My microcassette tape recorder stopped working.
It is possible that the rubber drive belt has broken or the motor is bad. Turn the volume all the way down,hold the unit next to your ear and put it into a function. Listen for motor noise, a slight buzzing noise. If you hear that it is possible the the motor is good and the drive belt is broken.
Oct 29, 2012 | Audio Players & Recorders
Jvc dvd player won't open
when you hit the eject button try tapping the top above the disk drive. it may be somewhat stuck. if that doesnt fix it you might have a broken belt or a belt may have come off in it. the belt controls the movement of the drive in and out
Mar 21, 2012 | JVC DVD Recorder - VCR Combos: DVD...
Teac A170S won't play, RW, FF, or record.
Hello
Can you hear the motor running, when you press any of the Play, Rew or FF buttons?. Just place your ear very close to the player and listen to it. If the answer is 'yes', the drive belt is broken or slipped off. You have to replace the drive belt. If the answer is 'no' the motor of your device's drive mechanism has damaged, and should be replaced. OK.
WISH YOU A PROSPEROUS 2012.
Gopakumar G, Kerala State, South India.
Dec 25, 2011 | Audio Players & Recorders
I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Jul 24, 2010 | Crosley CR248 Turntable
Describe your Harman Kardon CDR30 2-Disc CD Recorder Problem It's a CDR26 and neither of the drawers will open.
With mine, it was the drive belts for the cd drawers, which were stretched and rigid. Open the case. Remove the 4 screws that hold down each cd drive. Push the drives out enough so you can pull the silver facing off the sliding try by pulling it up. Now you can lift out the cd drives, removing all the connectors as you go. Flip the white plastic slider underneath each drive and you can mechanically open the slide tray. This reveals the little motor and rubber pulley belt that operates the slide tray. If the belts are broken, perished, rigid or something, get something similar from your local electronics parts store (a couple of bucks each belt), and reassemble.
Feb 11, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
Durabrand Tape/CD Player twists up all cassettes inserted
We have two of these with the same problem. The belt that drives the pick up reels is broken. We are trying to find a place to purchase new ones.
Mar 26, 2009 | Durabrand CD Player with Cassette...
I have a Panasonic DVD recorder which is approx 4-5 years old (model EM 10 ?). The machine will play original DVD's but will not play copied DVD's or CD's (even copied DVD's using the recorder itself). The...
This player had problems playing copied discsfrom other machines but should play its own.Have you been finalizeing the discs? if not do this when you record a disc,also try useing cheap dvds.Lastly if the player is still makeing funny noises it may need a new dvd drive.
hope this helps.
CABLE GUY.
Jul 16, 2008 | Audio Players & Recorders
Panasonic dvr,
If you hear the motor whirring then the drive belt may be broken. Pushing the buttons will not work. Someone will have to open it, remove the disc and replace the belt (if it's broken).
Feb 17, 2008 | Panasonic DMR-ES10 DVD Recorder
20 people viewed this question
Top The Audio Players & Recorders Experts
ctlimey
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
