Question about The Computers & Internet
Versed motion E1.1 is saying unfortunately the launcer3 has stopped please help course I can't do anything
How do I make the launcher3 from stopping every time I turn on my tablet and make my Google play app work
That is what happens when you have no network connection. Are you sure you are connected. Also are you sure you are logged in to Google?
Dec 27, 2014 | Tablets & eReaders
I removed the hand wheel cover on my Bernina 1001 because the wheel was too tight and now I cant get it to do anything...sew, wind bobbin. Help
With the wheel on you will have a 3 pronged washer, make sure that the screw on the stop motion wheel is unscrewed all the way, put the stop motion wheel back on ans tighten it hand tight only, tighten the screw in the stop motion and see if the stop motion frees off and then tightens again so the machine will work, if it does not take the stop motion wheel of again and move the 3 pronged washer in a different position and put the stop motion wheel back on again
Oct 04, 2013 | Sewing Machines
How to get a broken drill bit out of the crank pully shaft ona 95 Dodge Neon???
Unfortunately you might be in need of an expert. Drill bits are hardened, unlike your crank shaft. A machinist is usually well versed in broken bolt removal and they might just have an ultrasonic extractor. Getting a broken off hardened anything in usually not something I would recommend to the un-experienced.
Apr 21, 2013 | Cars & Trucks
I bought a dual sew sewing machine, Insturction model says Model DS-2000/DS-3000 from someone that was moving today. They have only used it once. I wanted to start by threading the bobbin. The problem...
unfortunately if you weren't able to test the machine before purchase you may have bought a dud. depending on where it was stored, it could be seized up. Non the less, any reputable sewing machine repair shop will help you with this specific prob for little or no cost
Feb 20, 2011 | Sewing Machines
My rolex datejust watch has stopped working...rolex watches don't operate on batteries right? Why has it stopped ticking?
mcdevito75 here, The answer is no, Rolex watches do not operate with a battery. Most Rolex watches are Automatic winding with the motion of your wrist / arm. Of course if you leave your Rolex on the dresser for say 30 hours, it will run down, simply hold the watch in your hand and with a gentle rocking motion say from 6--to 12 O'Clock for about 30 seconds, this will give your automatic Rolex an initial wind up, from there you just wear the watch and it will continealy wind itself. You may also have the non automatic Rolex in which case you would have to wind it dailey. If your Rolex will not run at all no matter what you try, Check out the repair service directory here at fixya, bottom of the page click on repair service directory then watches.
Aug 01, 2010 | Watches
How to make an animation?
u will have to attend certain courses of animation
u can buy a program name "MAYA 3D max"
view its tutrial frm the net
and be a beginner expert in animation
Mar 14, 2010 | Computers & Internet
I was embroidering with my machine and then the needle starting stitching in slow motion and then stop and I got an error saying the safety device had been activated. I closed that window and now it is...
Unfortunately you are completely dictated to by the computerized machine, you can only try and do what it says, if you have problems with any computerized machine the only solution is to get it to a Brother dealer or find their website for advice.
Nov 01, 2009 | Brother Sewing Machines
Bulova Watch Millennia Motion 96B17 - stops - needs battery????
Dude, of course it stops during the night - it's a perpetual motion / kinetic watch. It doesn't have a conventional battery. When you move your arm (while wearing it), the natural motion of your arm will 'automagically' wind the watch. There's nothing wrong with it - these types of watches always have to be re-set in the morning if you don't wear it to bed (or you don't toss and turn in bed).
May 30, 2009 | Bulova Millennia World Time 98G66 Wrist...
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
