Question about The Office Equipment & Supplies
What is the matric aggregate? - The Office Equipment & Supplies
Where do i go to restore my lost matric certificate
Certification Services - Department of Basic Education
www.education.gov.za/Informationfor/CertificationServices.aspx
  1. Cached
A change to an original certificate will not be considered unless the original certificate (not replacement) is returned. To change your name on your matric ...
Replace matric certificate ' South African Government
www.gov.za/node/727532
  1. Cached
  2. Similar
Apply for replacement of your matric certificate at the Department of Basic Education if you have lost or damaged your original matric certificate. You can request ...
Career Planet » Where can I get a replacement matric certificate?
www.careerplanet.co.za/where-can-i-get-a-replacement-matric-certificate
  1. Cached
  2. Similar
I lost my matric certificate. I damaged my matric ... Replacement (re-issue) matric certificate? I need a new ... (2) I damaged my matric certificate! What must I do?
Youth Village How To Recover A Lost Or Damaged Matric Certificate ...
www.youthvillage.co.za/.../heres-how-to-recover-your-matric-certificate-after-losing-i...
  1. Cached
Nov 26, 2015 - Please note: Applying for your lost or damaged matric certificate might differ from one province to another. Below is a guide to applying for ... restore my lost matric certificate Google Search
Jan 04, 2017 | Office Equipment & Supplies
I can't remember my matric examination number, can you help me please?
sadly we have no way of getting that information here on FIXYA
Jan 03, 2017 | Office Equipment & Supplies
What are the limitations for configuring link aggregation and protection on the ETHA, ETHB, and GIU boards?
The ETHA board supports only intra-board aggregation groups and protect groups, but does not support inter-board aggregation groups or protect groups. In addition, the ETHA board can be used for cascading but not for upstream transmission.
The ETHB and GIU boards support both intra-board aggregation groups and protect groups, and inter-board aggregation groups and protect groups. Inter-board aggregation groups and protect groups can be set up only between the ports on the boards of the same type. For example, a port on the ETHB board and a port on the GIU board cannot form an inter-board aggregation group.
When setting up an aggregation group or protect group, pay attention to the following points:
· A port can be directly added to a protect group. Or, it can be added to an aggregation group and then to a protect group. A port that has been added to a protect group, however, cannot be added to an aggregation group.
· Switching is of low efficiency between the ports that are in a protect group only, but switching is highly efficient between the ports that are both in an aggregation group and in a protect group. In this case, it is recommended that you add ports to an aggregation group and then to a protect group. This shortens service interruption.
Jun 07, 2016 | Computers & Internet
Keeps beeping but its not overfilled
Check the temperature and how long the aggregate runs.
If it is not cooling check the thermostat and the aggregate. Perhaps you even lost the cooling fluid. (used to be called Freon, but freon should not used today)
Mar 15, 2015 | Refrigerators
I have a ge gsh25jfta bb fridge.the power cut off one day and the display would not work, I messed with the back of display and it started working. Power went out last night and I can't get it to start...
Just check if any voltage is coming to the cooling aggregate. If so, and the aggregate does not run, it must be defect. When you can't measure the voltage on the aggregate, follow the leads back to the thermostat and other switches in the way.
You also could start from the mains, but I thought you had checked that already.
Feb 18, 2015 | GE Refrigerators
What is the correct ratio for mixing concrete?
generally about 2:3 water to cement. it should say on the bag, if it is too watery add more powder, if it is too thick add more water
Jan 15, 2013 | Building Materials
How do i multiply to 4x4 matrices using fx-991 es ?
The enclosed screen capture shows all the possible dimensions for matrices on the Casio FX-991ES. As you can see the maximum dimension of any matrix is 3. You can only create matrices with dimensions less than or equal to 3.
Dec 01, 2010 | Casio FX-115ES Scientific Calculator
How to solve 7*3 matrices on casio scientific calculator
The enclosed screen capture shows all the possible dimensions for matrices on the Casio FX-119ES/991ES. As you can see the maximum dimension of any matrix is 3. You can only create matrices with dimensions less than or equal to 3.
Nov 30, 2010 | Casio FX-115ES Scientific Calculator
I have a Casio fx-115ES; I have followed the manual for creating and multiplying matrices. The matrices have been simple, 2x2 for each, but it returns with "Dimension Error". Any suggestions? Thank you for...
Calculator should be in [MATRIX] MODE
Try the matrices 2X2 matrices matA [1,2,3,4] matB [5,6,7,8], Add them, subtract them, multiply them, take the square of each. If that works for these matrices, then it must be your data. Be careful with negative numbers. To enter those, you must use the change sign (-).
There is also the possibility that the instructions were misread.
Dec 14, 2009 | Casio FX-115ES Scientific Calculator
22 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
