Question about Beko Dishwashers
Beko dishwasher DSFN1534B shorts and arcs when you open the door. Electrician says it is dangerous. Just over one year old.
  • 2,597 Answers
Yes very dangerous turn off the power contact makes hotline this maybe under warranty.
Posted on May 15, 2017
Beko de2542f dishwasher
If you live in Rancho Cordova, CA and need dishwasher repair service call us at 916 823 3070 or visit our website Dishwasher Repair Rancho Cordova 916 823 3070 GE Maytag Ken
Sep 03, 2017 | Beko Dishwashers
The door on my beko dishwasher now just drops open ,how can I fix this please
The spring or nylon cord attached to door hinge has probably snapped. take side off both sides for simple fix. if not then the plastic catch at top of door is probably not engageing correctly. good luck
Apr 13, 2011 | Beko 24 in. D3421F Free-standing...
Beko 4310 stopped mid wash and no sign of any power. have checked fuse and mains, no problem... machine just over 1 year old... any ideas?
I am assuming it is a beko dwd4310 dishwasher.
If the display has totally blanked off then the control board has packed up.
You can find the part at this site.
Nov 07, 2010 | Beko Dishwashers
Water is not going into beko dishwasher de2542f .you can hear and feel water going through the pipe but is not going into machine
My BEKO dishwasher is turned off but there is a constant dribble of water running in to the machine. If I open the door when this has happened, it leaks water all over the floor. This means I have to keep turning the machine on to drain the water away.
Feb 06, 2010 | Beko 24 in. D3731F Free-standing...
Dishwasher is kicking out ground fault everytime it is turned on
first have an electrician check the ground fault breaker to make sure it is not weak or no good. if it is good do not use this dishwasher it has a dead short and could be very dangerous. call a repairman. dont mess with it
Jan 24, 2010 | Frigidaire Dishwashers
Dishwasher is shorting out and playing music. if you touch the front you get shocked
you have ashort from a hot wire or switch grounding to the frame somewhere, it would be best to have a electrician look at it i would not use this until you get fixed it is very dangerous
Nov 17, 2009 | Fisher and Paykel 23 in. DD603H SS...
How to change the timer on beko d3421 dishwasher
if you open the door and look on the inside at the top you should see same cross head screws undo these and the panel on the front should come free. now remove front off dial by just pulling it off you should two brass looking cross heads which hold the timer to the panel. pull the wires of the timer make sure you put the wires back the same way and done.
Apr 09, 2009 | Beko 24 in. D3421F Free-standing...
My BEKO D3421F dishwasher wont start?
hi there......sounds like the door switch on your apliance has given u...open the door close it firmly lidstening for an audible click as the door switch makes...
regards SirGalahad
Mar 15, 2009 | Beko 24 in. D3421F Free-standing...
Stopped partway through rinse cycle, doesn't power on again...
The problem is probably in the cycle switch/timer assembly. It probably burnt/shorted some contacts. This switch is of pretty intricate design, a bunch of wires run in and out of it and the turning action of the switch/timer opens and closes different contacts for pumps, heater, detergent door, etc... at different times in the cycle
Dec 20, 2007 | Danby DDW496W Free-Standing Dishwasher
Dishwashers Logo
23 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
