Question about Stanley Air Tools & Compressors
Why does the top a stanley oil get red when heathing up
Sir, Iam using the ZED-10FX Allen & Heath mixer. Iam not getting the 48V phanthom power and AUX out from the mixer both Green and RED LED on Phanthom power is not glowing. Iam getting the LED VU m
sOMEHOW YOU BLEW THE 48 v PHANTOM SUPPLY.
Open it up and check power board voltages.
Replace regulator circuit and check for shorts on your mic cables.
PEACE---
Feb 09, 2015 | Allen & Heath ZED-10FX Sound Mixer
Still an issue with shooting staples. the gun just clicks
Have you been oiling it regularly? Compressed air is very moist so a few drops oil oil in the unit is needed every once in a while to lubricate it properly, try and see what happens.
Dec 06, 2014 | Stanley Bostitch Ehf1838k Engineered...
Sh5412. The red lite blinks when walking past but the spot liters do not come on. The test was ok
What test did you do? Did the floodlights come on with the sensor switch in the Test position? Did you wait two minutes after turning the circuit on? Is the sensor in the dark? If your answer is yes to those questions, then try the following:
Double check the wiring. Sometimes a wire will come loose if the stranded wire from the fixture is wrapped all the way around a solid house wire. The solution is to gently bend the bare tip of the solid wire in a soft s shape so that the stranded wire does not completely wrap around the solid wire when the wire nut is twisted. (I know that you said the sensor red light is coming on but the additional load of the floodlights' current may not flow if there is a loose connection, very little current needs to flow to operate the sensor.) (The wires should be connected something like this -White from house to white for sensor (and to whites for lights unless this light connection is done internally in the sensor by Heath Zenith), Black from house to sensor, Other colored wire from sensor to lights (again unless this light connection is done internally in the sensor by Heath Zenith)- Also check that the spotlights are not burnt out and that they are tight in the sockets.
http://www.heath-zenith.com/servsup_instvideos.htm
Oct 22, 2014 | Heath Zenith Secure Home Motion Activated...
I need the location of the oil plug.
well stanley doesn't know and since you provided no information, I dont either
Nov 29, 2013 | Stanley Oil Fill Plug
What oil do i put in a compressor (I have a Stanley 50 liter unit) ?
Compressor oil is different than engine oil. Compressor oil can be found in places like Harbor Freight or any place that sells air compressors
Aug 25, 2013 | Stanley Air Tools & Compressors
After 15 or 16 coils, it would not fire. took top
Look on ebay for rebuild kit # RN46-RK , this kit has all the parts needed to restore to like new. The kit is easy to install and should last for many jobs to come. Be sure to oil the nailer once or twice a day with a few drops or bostitch oil or any nailer oil. It is sold a Lowes for about $3. Good luck
Oct 09, 2010 | Stanley Bostitch Rn461 Gun Coil Roofing...
Type of oil used in pancake stanley compressor
An air compressor should have 30 weight non-detergent oil only, or it will foam up and not oil the bearings.
Sep 20, 2010 | Stanley NEW Bostitch 2 HP 6 Gallon...
Need to wire motion sensor to light, have three wire(red, black & white), need to know how to hookup wires? my model no. is :-heath zenith sl-5318-bz-a
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
Feb 22, 2010 | Heath Zenith SL5316WHB Replacement...
How to basically operate my stanley fatmax, TLM100. The directions that came with it were for another Stanley product. Thanks,Ralph
Press the red button - (distance) you will see a red dot on the wall you are measuring - then you will hear a beep - release the button and read the display - the measurement should be displayed and accurate within a quarter inch.
Nov 16, 2008 | Stanley 100 ft. Tape Measure, FatMax
Air Tools & Compressors Logo
32 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
