Our WM009 turns off after 30seconds or less of cookong time.
My microwave model number is WM009. I am unable to change the current clock time. How do I do this?
push clock the up or down then clock again till its set then start
is what I would try
Dec 21, 2016 | Microwave Ovens
My hp stream notebook pc13 will not start up the screen lights up but only goes to the hp sign then blank
Hi! Some Times You Need To Do This
Unplug The Laptop
Take Out The Battery
Press The Power Button 15 Times And Then Hold It Down For 30Seconds
Put The Battery Back In The PC
Plug The PC Back In
And Try To Turn It On
Good Luck!
Nov 10, 2016 | HP Computers & Internet
What is convection cookong
A convection microwave is a combination of a standard microwave oven and a convection oven. It allows food cooked in the convection microwave to be cooked quickly, yet come out browned or crisped as in a convection oven. However, most cakes cannot be baked in a microwave oven - only those without an open grain structure, such as brownies. There are microwaves which contain electric browning baking elements. A true convection microwave has a high velocity forced air fan to circulate the hot air uniformly.
more about Convection microwave
May 28, 2016 | Microwave Ovens
My Qmark electic heater keep tripping the breaker
You will need to provide additional diagnostic information. Most likely the breaker is defective. Warning: potential for injury is HIGH working on power electrical! Do not attempt if you do not have experience and training. Proper personal protective equipment and methods should be used. The running amps needs to be measured when the heater is turned on. Find the rating on the breaker and calculate 80% of this rating. The heater current should be less than this value. If the breaker is tripping when less than 80% is measured it is most likely defective. Measure all power legs on the heater. Also check the nameplate info on the heater Volts, Amps. Compare these values to the actual.
Feb 06, 2015 | QMark MUH (0521) Compact Heater
How do I reset ecu after long disconnection of it's battery?
Usually depending on your vehicle, you turn the car to the on position for 11minutes,turn it off for 30seconds and it boots itself to the vehicle. That is for when you get a new ecu. Now if the battery has been disconnected for some time then it basically resets itself.
Aug 06, 2014 | 2007 Volvo C70
key in turn but dont start, then push in the small knobs beside clock and hold for 30 seconds if that doesnt work push in and hold right for 30seconds.
Aug 23, 2010 | 1988 Toyota Land Cruiser
My gps does no get a valid gps signal
Try resetting the unit using the 30-30 (30seconds with power on , 30seconds with power off , holding the reset button down the entire minute) Take the SD card out first. Then replace the SD Card with the power OFF. Turn back on and it will take up to 20 minutes to locate the Sats the first go.. bd
Jul 26, 2010 | Digi MAXX tal Media Explorer I Car GPS...
Configuring D-Link DIR 615 with comcast modem,,
Disconnect the modem for one minute, turn it back ON, wait for all the lights to sync with the Comcast.
While you are waiting for your modem to do its thing, reset your router with a pen for 30seconds. Then power it off.
Connect CAT5 cable from Modem to router, from router to PC, turn ON the router.
Make sure under your NIC TCP/IP settings that your PC acquires IP automatically from the router.
In less then a minute you should have internet access from your PC.
Aug 09, 2009 | Computers & Internet
I'm going to buy a new one. I paid less than 25 dollars for this one. It's cheaper to get another than to pay more than it costs to have it diagnosed. Thanks.
Apr 12, 2008 | Televison & Video
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
