Question about Miscellaneous
If 13 = 1001, 19 = 10013, 23 = 100004, A = 1000001, 139 = B Find the missing values for A & B.
    Master:
  • 923 Answers
Yeah, so what? Can you prove otherwise?
Posted on May 15, 2017
Testimonial: "What are A & B?"
  • 2 more comments
  • solver2010 May 15, 2017
    You already answered both questions:
    A=1000001, 139=B
    Did you want a different answer?
  • Shush Maisuria
    Shush Maisuria May 16, 2017
    The formatting of the table gets changed by the website.
  • solver2010 May 16, 2017
    Then try re-posting the question again, in column format, such as:
    If:
    13 = 1001
    19 = 10013
    23 = 100004
    A = 1000001
    139 = B
  • solver2010 Jun 08, 2017
    Clearly, you already said that A = 1000001, and 139 = B. If 139 = B, then B = 139.
I have my grandma's old Singer machine. Serial # is G8157312. Would like to know how old it is and what is the value.
June 1920
Value is not easy, but they are not worth as much as you probably think it is.
  • Antiques > Sewing (Pre-1930) > Sewing Machines ' eBay www.ebay.ca > Antiques > Sewing (Pre-1930) Visit eBay for great deals in Antiques > Sewing (Pre-1930) > Sewing Machines. Shop eBay!
  • Miss Sews-it-all: How Much Is My Old Sewing Machine Worth? sewsitall.blogspot.ca/2013/08/how-much-is-my-old-sewing-machine... Antique Singer Sewing Machine Value from Antique Singer Sewing Machines. Submitted by Miss Sews-it-all at 11:20 AM. Email This BlogThis!
    Serial Numbers Comprehensive Singer Sewing Machine Serial Number Database
  • Jun 12, 2016 | Singer Sewing Machines
    Can anyone tell me the value of the resistor in a Kitchenaid K5A mixer. I think mine grew legs and walked away. Thanks, Mike
    Are there any colors on the resistor or it is missing. If you know what the voltage and current should be in the circuit you can calculate the resistor value.
    May 08, 2014 | KitchenAid K45SS Classic Stand Mixer
    Missing value table y
    You are not being clear so I will have to guess what you mean.
    If you press the Table key without entering a function in the Y= editor, you will only generate the x-values but not the y-values. The calculator has no way of knowing what function you have in mind.
    Oct 17, 2013 | Texas Instruments TI-83 Plus Calculator
    Tv model:48s9156903 q402 mosfet missing. i need it's value capacitor c406 missing. i need it's value
    sir just take it to service center..........as you will damage another things also...........as c 406 is rarely available.........
    Oct 02, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
    Outlook express: the "accounts" item has gone missing.
    Issue: You need to edit the registry key to get the "Accounts" icon back to Tools.
    Resolution: Go to Start>Run>Type: regedit. Locate this key:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Outlook Express
    On the right-hand side of the page, double click: *No modify accts*
    value. {If this value does not exist, on the Edit menu, click DWORD Value.
    Type: No modify accts, and press Enter to save the name}.
    Change the setting of this value from 1 to 0, click OK.
    That should put it back in the drop-down box.
    Regards
    Atith
    Jul 05, 2010 | Microsoft Outlook Express
    Need value of capacitor on the first USB port missing from computer
    that is likely just a bypass capacitor across the 5 volt line .. its value is not critical .. a 0.1 microfarad ceramic should be fine ..
    Mar 01, 2010 | Acer Aspire 5335-2257 Notebook
    Error 1606
    Re: Please Help Unable to Install TIVO Desktop -- Error 1606. Could not access network location %APPDATA%\
    The response to "Echo %appadata%" should be
    C:\Users\UserName\AppData\Roaming
    A space in the user name shouldn't be a problem, but creating a new user may fix the problem because it will create the account with default registry settings which will hopefully have the missing %appdata% information.
    If you want to check on this before creating the new user, just for curiosity's sake, check the following Registry key:
    HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders and check the value for AppData in the right hand pane. If it's missing, then that would explain the problem. It should be as listed above, substituting the UserName with the folder name for the user under Users.
    Also check the key
    HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
    The value of this key should be
    %USERPROFILE%\AppData\Roaming
    More keys to check:
    HKCU\Volatile Environement (1)
    HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
    HKU\Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
    HKU\Sxxxxx\Volatile Environement (1)
    The values in (1) should have the full path spelled out, the values in (2) should use the %USERPROFILE% variable in the path. If the value under HKU\.DEFAULT is missing or bad, then creating a new user probably won't work either. If that value is missing, then I would recommend a clean reinstall of Windows because there is no telling what else is messed up also.
    The value for AppData in the registry key HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
    is C:\Users\Murray Admin\AppData\Roaming
    In the key the key
    The value for AppData is %APPDATA%
    The value for Local AppData is %USERPROFILE%\AppData\Local
    In HKCU\Volatile Environement (1)
    The value for HOMEPATH is \Users\Murray Admin
    In HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
    The value for AppData is %USERPROFILE%\AppData\Roaming (all the keys have the %USERPROFILE%\ )
    In HKU\Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
    The value in one of the \Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\UserShell Folders keys for AppData is
    %APPDATA% (Missing the %USERPROFILE%\ ) --- Could this be the problem???
    All the other values within do contain %USERPROFILE%\
    Do you think editing the key, adding %USERPROFILE%\ would do the trick? If so, it would be alot eaiser then
    a re-install. There is not much junk on it as this pc is only about a month and a half old. The other machine
    is about six months old. Both are from the same manufacturer (Compaq) but different models.
    Also - Using the set command the value returned for %APPDATA% are:
    Microsoft Windows [Version 6.0.6001]
    Copyright (c) 2006 Microsoft Corporation. All rights reserved.
    C:\Users\Murray Admin>set
    TEMP=C:\Users\MURRAY~1\AppData\Local\Temp
    TMP=C:\Users\MURRAY~1\AppData\Local\Temp
    Jan 20, 2010 | HP Computers & Internet
    ERR: DIM MISMATCH
    Check the values you entered into L1 and L2. One of them is missing a value.
    Jun 04, 2009 | Texas Instruments TI-83 Plus Calculator
    Missing resistor
    1.8 ohms at 2W
    Dan
    Sep 23, 2008 | Sharp 27H-S60 TV
    CD/DVD missing
    That means you have a missing driver.
    The solution is to load the missing driver.
    Use PC Pitstop to help you determine which driver is missing.
    Az.
    Sep 17, 2008 | Computers & Internet
    Miscellaneous Logo
    44 people viewed this question
    Top Miscellaneous Experts
    Andy Fraser
    Andy Fraser
    Dan Grod
    Level 1 Expert
    dennis lewis
    Level 1 Expert
    Are you a Miscellaneous Expert? Answer questions, earn points and help others
