Question about Avanti Washing Machines
Avanti portable washer W797 is stuck in test mode. When turned on it starts in C3, then beeps and lights flash and turns off.
4 Suggested Answers
  • 3 Answers
SOURCE: Avanti W797: Tub won't spin or water does not empty.
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
Posted on Apr 20, 2008
SOURCE: Avanti W852 Parts??
It's going to be hard finding parts for this machine because I have one as well. You can search the internet or call the company. The last time I had problems with my machine the company told me they stop making parts for this particular brand. Don't give up looking for parts, maybe someone else sells the parts for this washer. Good Luck!
Posted on Mar 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: i cant seem to turn
If there is power to the outlet the machine is plugged into...It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Avanti w797 does not drain. impeller keeps falling off.
Go to the following link:
http://www.avantiproducts.com/products/id/489
at the bottom of the page, click on the pdf "parts and accessories"
Nov 24, 2013 | Avanti W797 12 lbs Top Load Washer - White
Avanti very noisy while spinning
what is your model number is then we can get started then okay
Oct 01, 2012 | Avanti Top Load Washer W797
Avanti w798-ss e3 error
It seems there is a fault on the main controller unit of the washer. It seems to start and then drain off in mid cycle. Now choose a different program and see if there is any change. Also check individually the inlet valve, the water level sensor and also the drain valve. Also check all the connections to the main panel.
Mar 13, 2012 | Avanti Top Load Washer W797
The machine does not perform last spin cycle
check lid..either the lid switch is bad or the lid switch actuator which is made into top...when in final spin push down on the right hand top part of lid,,,if it starts replace part needed,,,good luck
Sep 12, 2011 | Avanti Top Load Washer W797
I can't find an adapter for my kitchen sink that will fit the hose end of the Avanti. Avanti customer service was useless.
Hi. Take the hose to most any neighborhood hardware store and they will fit it for you. Often, a local mom and pop hardware will be most helpful and knowledgeable. I assure you that there is a fix for your problem. J.
Jul 31, 2010 | Avanti Top Load Washer W797
Starting washer it beeps and flashes a F1 sign how do u fix
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Have a Avanti 798SS Washer. Does not wash nor does it spin. I heard something with the motor as if it attempting to perform said task (wash) but in the end it beeps and E2 flashes. What does this mean?
Oct 21, 2009 | Avanti Top Load Washer W797
Avanti w798ss doest start
Close the lid! There's a sensor on the back hinge of the lid. Make sure its working. You should hear a small click when you close the lid.
Nov 08, 2008 | Avanti Top Load Washer W797
Nov 20, 2007 | Avanti Top Load Washer W797
Washing Machines Logo
22 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
venugopal durairajan
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
