Question about The Computers & Internet
When I turn on the fire stick, the screen image rapidly scrolls through the listed offerings under HOME or refuses to acknowledge any commands
3 Suggested Answers
  • 10 Answers
SOURCE: images missing
What do you mean you are unable to get them to load. What happens? Are you receiving an error message?
Without knowing more, I'll take a stab and say try clearing your cache and cookies. This almost always resolves the problem when pages aren't loading correctly.
You could also try another browser (Firefox versus IE for example).
Parts Of BMW.
Posted on May 30, 2012
Terry Corrow
  • 10875 Answers
SOURCE: fire tv stick no home screen
unplug from power for 1 hour,then try again,if someone accessed it they could've damaged it
Posted on Jul 28, 2015
When I went to settings I accidently turned off blue tooth wi fi now remote will not allow me to do anything It will not scroll off home screen
straight from amazon,reset firestick,
Please unplug the Fire TV stick from power source and then plug it again after 5 seconds.
Once the Fire TV stick is back on, please take batteries out of the remote and re-insert
Apr 03, 2015 | Amazon Fire TV Stick
Accidentally turned off my blue tooth on my fire stick now my remote will not work
1,Before you pair an Amazon Fire TV Remote or Amazon Fire TV Voice Remote, verify that the remote is compatible with Amazon Fire TV, is within range, and has the required batteries installed. 1. From the Home screen, select Settings, and then select Controllers. 2. Select Amazon Fire TV Remotes, and then select Add New Remote. 3. Press and hold the Home button on your remote for five seconds. Fire TV Stick searches for the wireless signal of the remote. After the remote or game controller is discovered, select it from the list of discovered devices using your already paired, existing remote or game controller.
Apr 02, 2015 | Amazon Fire TV Stick
Accidently turned off blue tooth
I can not seem to get my pictures on my memory stick on my Sony Brava flat screen tv.
Try selecting on the remote 'Home' then on screen scroll to 'Photos' then down to 'Bravia images'
Feb 08, 2015 | Sony Cameras
I have a hiphone 4s and safari is in Chinese. How do I change it to english
  1. On the Home screen, locate and tap the icon that features the image of a gear:
  2. When the following screen appears, locate and tap the section that displays the same gear icon:
  3. On the next screen, scroll down and locate the group of settings that offers four options. Tap the third option in this group:
  4. On the next screen, tap the first option:
  5. Pick your language from the list, and then tap the bright blue icon in the upper right:
  6. After a few seconds, your iPhone, iPad, or iPod touch should return to the Home screen and display the language you selected.
source:http://support.apple.com/kb/HT2371
Apr 20, 2012 | Apple Cell Phones
When I try to graph it says "ERR: INVALID DIM". How do I get rid of that, so I may graph my equations?
1. TurnOff the STATPLOTS by pressing [2nd][STAT PLOT][4:PlotsOFF]. Command echoes on the home screen. Press ENTER. Screen displays Done
2. Run the command ClrAllLists to clear the lists. Press [2nd][Catalog] Scroll down till you reach the ClrAllLists command. Highlight and press [ENTER]. Command echoes on main screen, press [ENTER] to execute it. Screen displays Done
3. Make sure you are drawing the right type of graph. To check that press [MODE], scroll down to 4th line to highlight Func and press ENTER, if you are drawing y=f(x) functions. The others are PARametric, POLar, SEQuence.
The above procedures (the first two) are likely to solve your problem. In case that does not work reset the RAM.
Press [2nd][MEM][7:Reset][1:All ram][2:Reset] [ENTER]. Screen shows RAM cleared. Clear the screen and use [Y=] to enter the functions you want to graph.
Hope it helps.
Oct 13, 2009 | Texas Instruments TI-83 Plus Calculator
Intergers
There is no such button, but there is a command accsssible as follows
[MATH] right arrow to highlight [NUM] and 5:int( [ENTER] In short
[MATH][NUM][5][ENTER]
The command appears on home screen, where you give it the decimal number whose inter part you want.
Ex; int(15.87) gives 15
You shoul explore the catalog of all commands avaible on your calculator. You press [2nd][CATALOG] (under the digit 0) and scroll down or up. If you know the command, while in [catalog] press [ALPHA] and enter the first letter of the command. The cursor moves to the first occurrence of the letter and you can then scroll more to reach the command.
Hope it helps
Jun 04, 2009 | Texas Instruments TI-84 Plus Calculator
Nokia dbox
Go to bigmaq.co.uk. Important-download toolbar. On toolbar under the tab 'Keys' will be the latest key codes for all different the cable boxes. Click on the one you want & write it down. On Nokia Neutrino remote, press blue button for features menu, scroll down to Tuxbox commander, press OK. On more files, scroll to Keys & press OK. Scroll to key list text press 4, a list of key codes comes up. Scroll through codes until u find the same code with one digit out( near end of code) press 4 to highlight and change code number by pushing L-R or Up-Down. Push home button & when prompted save. push home button & all should be ok. If the code is changed in the next few days just go to bigmaq.co.uk and press keys tab for new code. Not as hard as it sounds. Love Hornet
Apr 13, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Computers & Internet Logo
Top The Computers & Internet Experts
tim brauer
tim brauer
Dilum Senarath
Dilum Senarath
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
