Question about HP Garden
Valve heads carbond up on 24 hp brigs and stration
    Master:
  • HP Master
  • 923 Answers
That's a pretty common problem on small engines, but I never heard of brigs and stration! If that really the name, I am surprised that the real Briggs & Stratton did not sue them for trademark infringement, since it looks somewhat similar!
Posted on May 15, 2017
Brigs Stratton engine stops at first compression point, when attempting to start. Has a new battery. Turning back manually and trying to resart, gets same results. help
if an older briggs engine say 8-15 hp
electric start may have sheared the flywheel key a fraction and put timing out
valve seats may have come loose and jammed a valve
or con rod come adrift
pop the head of the motor off and inspect
Apr 27, 2017 | Garden
Valve adjustment 16 hp briggs&stration
Adjust them with the piston at TDC on the compression stroke to .04
Adjust to .04
Oct 16, 2014 | Craftsman Garden
Adjust valves 16 hp briggs&stration engine
make sure you're on TDC... watch the valves. then adjust to .004~.006
.004-.006 remove the valve cover and if you need more help, you might want to consider a youtube video
Oct 16, 2014 | Garden
Need to adjust valves on troy bilt 17.5 hp brigs and stration motor
bad compression release or starter needs rebuilt
Sep 06, 2014 | Garden
Adjust governor
best to take in to shop let them adjust it govenors are tricky
Jul 27, 2014 | Cub Cadet Garden
24 hp brig motor does not seem to be getting fuel
the additive in gas eth. causes fuel lines to break down and not deliver gas to the carb. replace fuel line.
check fuel pump, remove fuel line to carb. turn motor over, if fuel does not spurt out fuel line replace fuel pump.
float in carb may be stuck, remove bowl from carb. and check needle valve, if gummed up clean.
Jun 02, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Torque specs. for a briggs @ stratton 24hp. head bolts
WHAT IS THE VALVE CLEARANCE ON A 23 HP. BRIGS MOTOR AND THE TORQUE ON THE HEAD BOLTS?
Jul 17, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
26 people viewed this question
Top HP Garden Experts
solver2010
andrewdwhite
ray gallant
Are you a HP Garden Expert? Answer questions, earn points and help others
