When is Bloodline going to be released on DVD?
Agree or Disagree- Anyone who race mixes with a Black just set their bloodline a million years back in terms of evolution?
But Back Thousands Of Years Ago Evolution Was More Advance The Mix Races Were Building City's Which Were Using Nuclear Technology, Like In Pakistan Mohenjo-Daro Destroyed By A Nuclear Mishap Bodies Still Lying On The Ground Radio Active To Day. Then There Is The Diamond Sutra The Oldest Known Chinese Dated Print Book In The World, Which As The Blue Print Of The Cosmic Mountain The Blue Print For A Particle Beam Exelarator, Which Would Need Huge Amounts Of Power To Operate This Weapon, Don't Knock The Bygone Peoples, Aliens Were Teaching Them Modern Day Advances Thousands Of Years Ago.I Wonder Who Is Helping Now, Spirit Walker Peter Gore Seer.
Jan 04, 2017 | Politics
Best cheat codes for infinity blade III on ios
Restart bloodline 1, when you are fighting the dark knight and learning how to your shield. Purposely die by blocking and stop blocking before he hit hits you. After you die you start with a really awesome set of stuff that is not in the shop without this cheat. There is two other things for every type of item that you can get that you can\'t get without this cheat. The only problem is that you can\'t equip anything other than these awesome things.
Master Killer
First you must have less than 50% battery remaining so your device doesn\'t have enough power to catch this glitch. First make sure you have 0-100 gold ONLY. Now, equip a sword so that your hit points will equal 25. Now encounter an enemy and kill them using NO magic. Your gold should go up to 1900-5000. Now encounter another enemy and attack until their health is about 1000-1100. After you do this step, HIT (not scratch) them the same number as your hit points (25). EXACTLY on the 25th time pause and go to store and buy until your gold reads 500 or less. You want to have the most as possible. Now unpause and finish them. For the rest of the bloodline your sword will deal the amount of gold you have left (i. e . 467) Now you can just farm enemies.
Nov 24, 2014 | Video Game Consoles & Games
Hello sir..or who it may concern........while playing my psp or while going to my home page it suddenly goes to most left and then i cant go anywhere it stays right there.please tell me what to do...
I would suggest restarting the system. Shut down the PSP, remove the battery, let it stand for a minute or so, put the battery back in place, start up the PSP. When the PSP is starting, do NOT touch anything. Moving the control could cause the PSP to assume that moved position is the neutral base position. If this does not fix it, contact Sony directly.
May 28, 2011 | Sony PlayStation Portable (PSP) Console
Need to know what the emergency release button is for the DVD dri
Most DVD players have a small pinhole on front plate. Use a paper clip to trigger manual release.
May 23, 2009 | IBM (08K9648) DVD Drive
I have a lifestyle 18 bose system which only plays region 2 DVDs. How can I get it to play region 1 as well?
Hi, check below the media center/DVD player as to what region your system was fixed into (indicated by a number inside a globe). This is located underneath the unit just beside the serial number. FI the system indicates that your system indeed is set to region-2 then proceed as follows. IF it marks a different number region, then bring the unit to the Bose service center.
Steps in UNLOCKING REGION CODE of media center:
1. Load a DVD and wait for the display to show "REGION CODE ERROR, CONTACT BOSE"
2. Once this comes out, press eject button on your remote control but do not remove DVD disc
3. Press the following button commands in sequence (make sure they are in sequence and are pressed by looking into the media center display where a small green dot should blink indicating that each command is received).
4. First you need to initiate the system region change on the remote control:
a.while the tray is out and the DVD is still in the tray, press and release "RIGHT" arrow button
b. then press and release "UP" arrow button
c. after, press and release "SHUFFLE" button
d. then press and release "STOP" (black square symbol) button
e. lastly, press and release "MUTE" button and system should go on mute (indicated in the LCD display
After this, you now can change the region code by doing the following button press on your remote control:
1. While the DVD tray is out still and the DVD disc is in the tray, press and release "STOP" button (black square mark)
2. Press and release "SHUFFLE" button
3. Press and release number "0" button on numeric keypad
4. Lastly, press and release "ENTER" button on your remote control and the DVD tray should go back inside the DVD. The disc then should start loading and playing resumes.
5. Allow the DVD disc to run for a few minutes (if you want enjoy a full movie) to keep the region change resident before switching off again.
Now enjoy your Bose Lfiestyle DVD System REGION FREE!!!
Do note, this does not apply to Bose DVD system that are locked to region-1
Glad to be of service always!
Mar 03, 2009 | Bose Lifestyle 18 System
Jvc th m3030
Hello, if your dvd player is still under guarentee then dont do what I am going to explain, this is simple to get the dvd out undo all of the screws on the sides take the lid off and you should be able to get to the dvd, it should'nt damage the dvd if you push the drawer out to release the dvd.
Feb 15, 2008 | JVC XV-N422S DVD Player
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
