SC544 functional problems ERROR CODE ON REX ROTARY 1808D COPIER
ERROR CODE SC544 IN DISPLAY AFTER PAPER JAM
Fuser problem. Call for service
Posted on Jul 26, 2009
Kindly assist, clear error code sc542 on Rex rotary mp1900 copier.
see here http://copiers-orange-county.com/afficio-error-sc542/
Sep 15, 2016 | Office Equipment & Supplies
How do I reset fuser code on savin 2513 with a sc544. I have checked the fuser lamp thermal fuses etc. From the power source in cable unplugged. The thermistor reads about 390 k ohms at room temp. It had a...
When reading the thermistor, grasp the sensing part between thumb and forefinger, if reading drops quickly the thermistor is probably goid, if so , unfortunately you may need a power supply board
Feb 12, 2015 | Savin Office Equipment & Supplies
Clear error code on SC544
What is it on?? If a printer unplug it & wait 1 min & plug back in. If still does it go to the Manufactures web page & look in Frequent answers.
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Dec 14, 2014 | Office Equipment & Supplies
Savin 8045 sc544
error 544 is associated with the fuser, call aechnician to change the thermisters and thermofuse of the fuser and the problem is solved
goodluck
Feb 05, 2014 | Gestetner Office Equipment & Supplies
Rex rotary 8732z paper problem Give you an indication that there is no paper, but there is paper inside
Maybe it's just me, but do you think that "Chevrolet 1983 K1500" is the correct place for this question?
it sounds to me that your paper level sensing switch is jammed or broken. Look for a micro switch that has an arm that lays on top of the paper stack. It may be bent or broken.
May 20, 2012 | 1983 Chevrolet K1500
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
My Rex Rotary 1508 keeps returning an error code SC194 & won't work. What could be the Problem?
SC194 SBU White Level Detection Error
your optics could be dirty. your exposure lamp could be bad. your ccd could be bad.
clean the optics fist, then replace the lamp if cleaning did not fix it
Jan 06, 2011 | Gestetner DSm515pfd Digital Copier -...
Gestetner 3225 error code SC544 - functional problem
SC544 indicates low fuser temperature during the warm up process. This means you have a problem with the fusing unit heating up. The fusing unit is located right where the paper exits the machine. Most common failure on these Ricoh's (Your Gestetner 3225 is made by Ricoh model aficio 250) is the fuser thermistor. This is a small electronic part that measures the temperature of the fusing roller. When they go bad they do not "see" the heat and therefor the code pops up. You are going to need to have a tech look at this for you as you will need to determine for sure which part is bad then you have to go into the service mode to reset this SC code before the machine will run.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | Gestetner Copier
938 people viewed this question
k24674
jasbo
jasbo
