Computers & Internet Logo
P
Philasande Posted on May 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Khuse vlan names? - Computers & Internet
solver2010
Level 3:
  • Computers & ... Master 923 Answers
  • Posted on May 15, 2017
solver2010
Level 3:
Answers
923
Questions
0
Helped
192636
Points
2907
Without a doubt! I'm glad we had this highly informative conversation! When people give details like you did right up front, it makes it MUCH easier. Glad I could help you!
How to Change the Service VLAN to Which the xDSL Port Belongs
Changing the service VLAN to which an Huawei xDSL port belongs means changing the service port configuration, namely, the PVC configuration, of an xDSL port. To change the service VLAN, run the undo service-port command to delete the service ports (PVCs), and then configure a new VLAN for the Huawei xDSL port.
The prerequisites for deleting a service port are as follows:
When you specify parameters, all the matched service ports will be deleted.
A service port cannot be deleted in the following conditions:
The port is encapsulated as PPPoA, IPoA, or Auto.
The port contains the BTV user.
The port is bound with an IP address or a MAC address.
The port is configured with a static MAC address.
Huawei MA5600
Huawei MA5616
Huawei DSLAM
Hi,this is pavan i want to b configure the HP procurve 2626 J4900B managed switch pls help me through anybody by giving the programme to configure it
What do you need it configured to support? Multiple subnets? VoIP support?
Here's an example to support 2 subnets, VLAN 1 Data and VLAN 2 Voice. This switch is the VLAN router for the site and it is also the default gateway for all the devices on the network.
show running-config
Running configuration:
; J4899A Configuration Editor; Created on release #H.10.50
hostname "HP 2650 dot 11 layer 3"
snmp-server contact "Your contact info here"
snmp-server location "Server Rack - Upper Switch"
time timezone -5
time daylight-time-rule Continental-US-and-Canada
interface 49
name "Uplink to HP2650 port 49 - 192.168.105.12"
flow-control
exit
interface 50
name "Uplink to HP2650 port 49 - 192.168.105.13"
flow-control
exit
ip routing
timesync sntp
snmp-server community "public" Unrestricted
vlan 1
name "Data"
untagged 1-46
ip address 192.168.105.11 255.255.255.0
ip helper-address 10.50.3.2
tagged 49-50
no untagged 47-48
exit
vlan 2
name "Voice"
untagged 47-48
ip address 10.50.3.11 255.255.255.0
tagged 1-46,49-50
exit
ip route 0.0.0.0 0.0.0.0 192.168.105.1
spanning-tree Always turn on Spanning Tree
spanning-tree priority 0 This switch is the master Spanning Tree operator.
password manager
password operator
2helpful
I need to config a hp procurve 2610 with a data and voice vlan to work with my mitel.
hostname "Switch1"
qos dscp-map 101110 priority 6
vlan 1
name "Data_Vlan"
untagged 1-28
ip address 192.9.180.19 255.255.255.0
exit
vlan 2
name "Voice_Vlan"
ip address 10.9.180.5 255.255.255.0
qos dscp 101110
tagged 1-28
voice
exit
Program the port that the PBX is in as a untagged port on Vlan 2
I need to use the switch ports (WIC-4ESW) with my 1711 router it has 1 real lrouted Fast Ethernet and a 4 port 10/100 switch tht is only L@, someone how i have to make VLANS or virtual interfaces, if...
to make a VLAN you would need to log on to the router, get to config mode, and then type vlan [vlan number] name [text name for vlan] and press enter. This creates the vlan in the vlan database (vlan.dat in flash).
Once you have done this, create the actual vlan interface by typing int vlan x and pressing enter, and then configure this like a normal interface with an ip address, etc (don't forget to no shut the interface!).
You can then either assign the vlan to the interface by going to the interface with int [interface name and number] and pressing enter, then use the switchport mode access command to set it to an access port, and then switchport access vlan x to set the access to the relevant vlan.
Of course, substitute the x's in my examples for the relevant vlan numbers.
Hope that this is of some help.
2answers
VLAN
no competent guys out there ???
2helpful
Two different subnet in same vlan how to creat HSRP
You can only create HSRP within the same domain or per vlan .For instance for vlan 20 the config will be as follows:
Primary side
interface vlan 20
ip address 192.168.1.1 255.255.255.0 secondary
ip address 192.168.2.1 255.255.252.0
standby 1 ip 192.168.1.2
standby 1 priority 105
standby 1 track[ interface name]
standby 1 preempt
standby 2 ip 192.168.2.2
standby 2 priority 105
standby 2 track ( put the the outgoing interface which this group will check incase it goes down i.e wan interface)
Backup configuration
interface vlan 20
ip address 192.168.1.3 255.255.255.0 secondary
ip address 192.168.2.3 255.255.252.0
standby 1 preempt
standby 2 preempt
NB Make sure that your LAN devices have their gateway pointing to HSRP IP but not the physical interface for example for group 1 the HSRP IP will be 192.168.1.2.Do the same for vlan 50
Grand Canyon Tech
Grand Canyon Tech
