Question about Sewing Machines
Why does my needle hit the bobbin case? - Sewing Machines
  • Sewing Machines Master
  • 11,493 Answers
Either the needle is severely bent or the machine is out of time.
Posted on May 17, 2017
Needle hitting bobbin case
Try a brand new needle. Make sure it is the right needle for the machine and that it is installed correctly.
If the needle continues to hit the bobbin case, then there is a needle/hook timing issue. Take it for service.
May 16, 2016 | Sewing Machines
The bobbin case catches the needle and the thread wraps around the bobbin case
If you are saying the needle is hitting the bobbin case when it goes down then it could be one of two things:
1. Bobbin case not all the way in. This can be caused by debris in the rotary hook or the bobbin case has been hit by the needle and has cracked/and or bent it. Make sure it is snapping into place correctly.
2. The rotary hook is out of time. Reset the rotary hook point behind the needle and about the middle of the scarf of the needle. Make sure you run the needle all the way down and as it starts back up this is where you set the hook.
Oct 01, 2014 | Consew 255RB-3 Mechanical Sewing Machine
Needle hits bobbin case
The bobbin case has to be positioned properly in the race. When the stitch plate is removed the bobbin case can be inserted in the wrong orientation to the stop finger. So if I can the presser foot location 12 o'clock, the tension screw for the bobbin case should be at 6:15 and the stop, which I think looks like a little nose, should be at 5:45. This little nose like projection should nuzzle up against the stop. If the needle hits the bobbin case when the bobbin case is inserted correctly, go see a dealer, your machine is broken.
Dec 06, 2013 | Baby Lock Sewing Machines
I broke a needle while sweng,now my needle hits my bobbin case on my 2030
it's very possible that when you broke the needle it caused the machine to go out of time & would have to be retimed at a sewing machine repair shop
Mar 12, 2012 | PfaFF Tiptronic 2030
If the needle hits the bobbin case the are only 2 things that could be wrong. Lets hope its the easy one, there are more than one length of needles, if the needle is to long or it is not all the way up in the neelde bar, the needle will hit the inside of the bobbin case. Now if that is not the problem then the machine is out of time. ALWAYS check the easy stuff FIRST.
May 20, 2010 | Sewing Machines
My needle jams when it hits the tray the bobbin case is in. It looks as if the timings off because just to the right of where my needle hits is a dip in the tray. Almost as if the needle's too long. I've...
If this is a drop-in/horizontal bobbin, raise the needle to it's highest position. Remove the bobbin case then replace it so it fits snugly into the shuttle. Hand walk to see if the case moves freely in a circle. If it stops, it is not positioned correctly. You do not have to have a needle in to test this.
Once you are sure the bobbin case is correctly in place, re-install the needle. Hand Walk to make sure the case turns without any interference.
If the needle continues to hit, then the machine needs to go into the shop for service.
There is a DIY for adjusting the timing of the hook if you wish to try the adjustment on your own.
Mar 14, 2010 | Kenmore Drop-In Bobbin 505S-21BH...
Needle hits the bobbin casing.
check to see the bobbin is in correctly first, is the needle in the centre?
Nov 23, 2009 | Sewing Machines
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
