Question about The Office Equipment & Supplies
How to cancel the RF key - The Office Equipment & Supplies
Casio T-280; I need to cancel out a transaction. Haven't hit cash/check/charge; I want to do this without having to issue a refund
This machine is too cheap to have a void function so you will need to finish the sale with cash. Now you can reverse the transaction:
Turn the key to RF mode. Enter the items exactly as you did the first time. they will all be negative items now and they will go back out of the daily sales. Finish the sale with the same payment type (cash) and the machine will take the amount back out of the cash total. Now your sales report will have the correct figures.
If you want an easier method, buy a Casio with the CANCEL function and you can quit a sale at any time :)
If anyone needs a Casio PCR-T280 manual, one of the users has it here:
Oct 19, 2013 | Casio Parts Cash Register PC Desktop
I have a connex 4600 turbo with a road king 56 noise canceling mic. My mic just started making a cracklin sound in my external speaker . It also shocks and burns me. When I key up and let go it stays keyed...
Sounds to me like the RF signal is leaking into the microphone. Check the cable to the microphone and see if the ground wire is bad. Check the SWR to see if it is high. The problem you are talking about is unusual.
Jun 28, 2013 | Radio Communications
Major Problems With Directv Rc65rbx-Universal Rf Remote Control W/Batteries Backlit
There is no key to push to test the batteries. Just replace with new batteries to see if that helps.
Mar 14, 2013 | Directv Rc65rbx-Universal Rf Remote...
The variabel key drops sometimes drops when radio is keyed up and sometime the RF power knob has to be turned farther to bring it back up on my Galaxy DX959.
I'm not shure if you have tried but turn the mic gain down then check the d.k output. If you still lose power after a d.k it could be a final it's hard to say w/o seeing it. Also an external meter is more stable than the internal one. Check your coax, make shure all are tight. If you need more help e-mail me at no capital's
Good luck
Feb 16, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Re-set key on the Motorolla MC9090 RF Scanner
Take out the battery, press and hold the power button and trigger for 30 sec and push back the battery the release the buttons.
Jun 30, 2010 | Zebra Symbol Technologies MC909X-G Series...
2000 neon check engine light is on
P1685 Skim Invalid Key.
The Sentry Key Immobilizer Module contains a Radio Frequency (RF) transceiver and a microprocessor. The SKIM transmits RF signals to, and receives RF signals from the Sentry Key transponder through a tuned antenna ring integral to the SKIM housing. When the ignition switch is turned to the On position, the SKIM transmits an RF signal to the transponder in the ignition key. The SKIM then waits for an RF signal response from the transponder. If the response received identifies the key as valid, the SKIM sends a valid key message to the PCM over the PCI data bus. If the response received identifies the key as invalid, or if no response is received from the key transponder, the SKIM sends an invalid key message to the PCM. The PCM will enable or disable engine operation based upon the status of the SKIM messages.
you can look it up here:
Sep 13, 2009 | 2001 Plymouth Neon
Reprogram keys casio pcr-t265
I'm afraid you didn't pay enough to get advanced functions. this machine is barely better than a calculator on a drawer. It has a fixed keyboard so you cannot switch keys on the keyboard, and it does not support the cancel function that you need to cancel a sale. You can refund the items by turning to RF mode and then entering the items again to reverse them, but other than that, you need to ditch it, and get one with features.
Bargain price machines come with very few extras.
Jul 14, 2009 | Casio Parts Cash Register PC Desktop
Direct TV TC64R remote does not work in RF mode with RCA DRD486RH
The DRD486RH is both IR and RF capable but the remote that you have is obsolete.
Mar 04, 2017 | Televison & Video
20 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
